Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > West Virginia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
West Virginia Chapter Join Chapter, Leader: msgtg
  #1 (permalink)
Old 03-25-2009, 09:14 PM
Kanyonkitty's Avatar
Kanyonkitty Kanyonkitty is offline
Garage is empty, add now
Kanyonkitty is starting off with a positive reputation.
'05 PSD Block Heater Plug
I have an '05 6.0 PSD and I usually plug it in overnight. I notived 3 days ago, that my extenson cord had a melted spot on it, it's the same cord that I used last year. So, I put a new end on my extension cord, and it was again melted. SO, this morning when I unplugged my bus, I put that extension cord on my truck and when I came home 3 hours later, that cord had the beginning of a melted spot.
I took a closer look at the plug end on my truck and one of the "blades" was discolored and VERY LOOSE. Needless to say that cord for the block heater is really buried in there and super hard to get to, so can I just remove the plug end and put on a new plug ? And is it something that I might be able to do ?
Thanks for any help & information,
Kitty
  #2 (permalink)
Old 03-25-2009, 09:17 PM
EMD_DRIVER's Avatar
EMD_DRIVER EMD_DRIVER is offline
EMD_DRIVER is starting off with a positive reputation.
Yep and it's a whole lot easier, than trying to replace the whole cord!
I don't know if the PSD cords are the same as the IDI, but I believe the entire cord can be replaced... If yer feelin froggy!
__________________
*11 F250 6.7 CC LB Sterling Grey Metallic
*Early 99 CC Dually 4x4 auto 313,000 miles
*02 VW Jeta TDI.. 50 MPG and no batteries required!
*03 Sunline Solaris F-344SR fifth wheel
  #3 (permalink)
Old 03-25-2009, 09:20 PM
Thanks Gary,
And I took a look to see where the cord was routed, and "no thank you" for replacing the entire cord, what a freakin nightmare. I'd have to be a contorsonist to replace it.
Kitty
  #4 (permalink)
Old 03-25-2009, 09:22 PM
EMD_DRIVER's Avatar
Quote:
Kitty
Hmmmmmm! Might be time for a complete-with-pics write-up!!!!!
__________________
  #5 (permalink)
Old 03-25-2009, 09:30 PM
UMM, well since you thought of that, I'll provide the camera and the truck and you can figure out how to make your body parts fit where this cord goes You've seen under the hood what a jammed up mess is in there, that's why I'd rather try replacing the plug end first
But, I'm willing to drive it over for you to do it
Kitty
  #6 (permalink)
Old 03-25-2009, 09:35 PM
EMD_DRIVER's Avatar
I'll put a new end on it, if that's what you want... If the cord gets replaced, it will be YOU doing it with me TAKING the pics!
__________________
  #7 (permalink)
Old 03-25-2009, 09:48 PM
Oh gosh, I sure hope a new plug solves the problem, as for the other scenario, well, I'd rather not go there
Where do I get the plug end, find a dead PSD in a junk yard ?
Kitty
  #8 (permalink)
Old 03-25-2009, 09:52 PM
EMD_DRIVER's Avatar
Kitty
Lowes would be my first choice...
__________________
  #9 (permalink)
Old 03-25-2009, 09:55 PM
I might try the bus garage
  #10 (permalink)
Old 03-25-2009, 09:59 PM
EMD_DRIVER's Avatar
I don't think they would have anything. If you aren't replacing the whole cord, your choices are a bit limited.
__________________
  #11 (permalink)
Old 03-25-2009, 10:08 PM
Thanks Gary,
I'll get a new plug end tomorrow, and well, I might take you up on replacing it for me. Electrical stuff is not my favorite thing. I prefer power tools , I can saw, drill & hammer, but electric scares the bejeebees outta me,
Kitty
  #12 (permalink)
Old 03-25-2009, 11:00 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1997 Ford F-350
My Garage
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
If the cord routing is like an IDI, simple job from under the truck.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #13 (permalink)
Old 03-26-2009, 05:39 AM
Dave,
There is really really not much room ro run a new cord without it being a REAL nightmare of a job, so I'm hoping to try the new plug end first. Everything is just so darn jammed in under the hood, it's a real mechanics nightmare. "IF" the new end doesn't solve the problem, I'll have to get my bus mechanic to replace the complete cord I guess. He maintains my truck for me, as he does mechanical work on the side.
I sure wish it was as easy as an IDI,
Thanks,
Kitty
  #14 (permalink)
Old 03-26-2009, 12:39 PM
msgtg's Avatar
msgtg msgtg is offline
1992 Ford F-150
My Garage
msgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to behold
Hi Kitty, I just replaced my plug on the truck about two weeks ago.
In my case, the wire had a nick right behind the plug and I kept getting shocked everytime I plugged or unplugged.
If you peel back that plastic accordian cover, you'll see that one of the wires is plainly marked "Neutral". That's pretty much all we needed to know. I clipped the wire right behind the head of the plug so as not to lose any wire length. We skinned all three wires back. I picked up a heavy duty yellow plastic replacement plug and wired it up. When we closed the plug, we stuck the end of the accordian cover between the two pieces of the plug so now it's covered completely...no exposed wire to get nicked.
Joe
__________________
03 F250 King Ranch Crew 6.0 4x4 92 F150 XLT SuperCab 4x2 03 Intruder Volusia 03 Ranger XLT
WV Chapter Lead JOIN THE WEST VIRGINIA CHAPTER CLICK HERE
We live in the Land Of The Free...BECAUSE of the Brave! My humble thanks to all Veterans, past and present
  #15 (permalink)
Old 03-26-2009, 03:16 PM
Thanks for the info., Joe
I'll relay that info to Gary, as he picked up a new plug for me today, and I will be heading over his house for him to install it this evening . The truck is nice and clean right now, but it's raining here so it will soon be dirty once I pull out of the truck-port and then the cleaning process can start all over again. Dang, why did I buy such a big monster
Kitty
Tags
05, 2005, 2006, 60, 73, block, cord, f250, ford, heater, location, plug, psd, time
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
