Very Dangerous Steering Box Problem - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-25-2009, 10:02 PM
deckpros deckpros is offline
deckpros is starting off with a positive reputation.
Hello all,
A few weeks ago, my employees were driving home one of my work trucks, a 2001 F350 7.3 4x4 Crew w. 130K miles. They were on a straight road in a small town when the steering went completely out. The truck veered into a telephone pole. Thankfully no one was injured. The truck has major damage to the front passenger's side.
I finally got the truck back to my shop today. It is quite evident what caused the problem. The gear/splined shaft that protrudes from the steering box and is connected to the pitman arm sheared completely off. I can't seem to find this problem anywhere else on the 'net. Has anyone heard of this before??
I can get some pix tomorrow if anyone is interested.
Old 03-25-2009, 10:37 PM
DAVE67FD's Avatar
DAVE67FD DAVE67FD is offline
DAVE67FD is gaining momentum as a positive member of FTE.
Fully inspect the rest of the steering system including the pump, hoses tierods etc... It may be that another part of the system failed first causing the accident. My guess is the accident may have caused the shearing of the shaft. Did the passenger tire take a hard hit? Check the box for cracks.
It would be hard to think the shaft broke on it's own, It takes quite a bit of pressure to shear it off. How is the truck generally used?
Also ask your guys if the steering went loose or did it get hard?
Old 03-25-2009, 11:35 PM
Fordfanatic4life Fordfanatic4life is offline
Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.
i think maybe, just maybe ur employee's arent being competely upfront..
i bet teh accident happened and THAT caused the steering to sheer..
ask yourself:
what are the odds the steering failed first just in time to cause the truck to hit a pole ???
now ask yourself:
what are the odds the truck's passenger side hit the pole first, thus causing such stress to the steering gear it sheered the sector shaft off the steering box...
not saying anyones lying here, just the story doesnt seem right to me...
Old 03-26-2009, 12:24 AM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
I have to agree with everyone else. The force to sheer that big splined shaft should have bent the drag link or tie rods first.
Although, you may want to look at the direction of the sheer and grain of the metal. I can't remember right now, how the direction goes though. I think it will ripple be perpendicular to direction of sheer, then the angle should show the vertical direction of it.
Old 03-26-2009, 03:24 AM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
I gotta be honest, those were my exact thoughts.
Stewart
Old 03-26-2009, 07:38 AM
110Dave's Avatar
110Dave 110Dave is offline
110Dave is starting off with a positive reputation.
I had my steering box splined shaft (sector shaft?) shear on me on my 99' with 38" tires and a 6" lift. The current truck that I just picked up, an 03' with a 7" lift and 37" tires also had the shaft shear. It seems that with larger tires and lift that its compounds the stress on the steering box.
Old 03-26-2009, 07:42 AM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
The only time I've heard of this has been on trucks with a lift. Seems like there's a different arm you can buy to come off the steering box to prevent this.
You didn't mention if the truck had a lift. I've got a half dozen 99 - 03 trucks, none with miles that low, and have not had any steering linkage issues.
Old 03-26-2009, 09:56 AM
Hi all,
Thanks for the replies. The truck is not lifted. And my employees lie to me?? NEVER!! Ok, it wouldn't be the first time... or the second, third or fourth..
The front wheel contacted the curb before the truck hit the pole, so that may have caused the problem. I'll check out all the other steering stuff if it stops raining today.
If any of you are good with body work and looking for an F350 diesel, keep an eye on eBay in the near future.
Old 12-23-2012, 08:25 AM
Bobmurp1 Bobmurp1 is offline
Bobmurp1 is starting off with a positive reputation.
I know this is a old post but I had a 02 with 35000 miles sheer the saft off. I was driving on a back road luckily nothing happened
Old 12-23-2012, 11:40 AM
davidzog's Avatar
davidzog davidzog is offline
davidzog is starting off with a positive reputation.
It seems that when Ford or GM or anyone designs a truck, the engineers (that are smarter then I am) understand stress relationships and metalurgy, etc.
Then non-engineers (the customer) mess with the structure and are surprised that the extreme extra stress causes components to fail. Then, it becomes a Ford or GM issue.
My nephew put a 5 or 6 inch lift on his Chevy 2500 2 years ago. The lift manufacturer recommended some heavy duty caps that bolted over the tie rod ends. These parts were not included in the kit but were extra cost. My nephew opted NOT to but the extra parts. While off-roading a few weeks later, a tie rod end failed and the wheel turned sideways are ripped the spindle off the truck, tearing out the febder well....luckily he was not on the hiway when the tierod failed.
He blamed GM for making a crappy truck and now has a Ram with a lift kit....ouch!!
Don't get me wrong, as I really like a great looking lifted 4x4.....but there are thing the need to be considered.
Regarding this specific issue, I concur the the wreck happened first, causing the pitman arm to be sheare off..that just makes the most sense.
Old 12-23-2012, 03:22 PM
Kdr358's Avatar
Kdr358 Kdr358 is offline
Kdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to behold
this is now the 4th or 5th post of someone having this dangerous failure..
Old 12-23-2012, 04:23 PM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
This happened on my 2000 as well. The break happened while parking at work so thankfully nobody was hurt. I had about 5 years of oversized tires so I'm sure it just worn out... Couple of pics below:
Old 02-02-2013, 03:38 PM
Justin1989 Justin1989 is offline
Justin1989 is starting off with a positive reputation.
Deckpros: Your employes are not lying to you.
I have an 02 that I had the same thing happen to me in my 02 in a parking lot. My truck also has a 12in lift... My buddy has a 99 that only has a 6in lift and his broke goin down the road causing him to go off the road and hit someone's garage. There's not a doubt in my mind that the accident is what they say especially in a work crummy as we all know they take a little abuse. When you put on new steering box (I got mine a reman from the wrecker for a $100) use a little locktite when bolting pitman arm on. Provided I'm running 40 in tires I'm not a small guy and I tightened the hell outta mine and it still turned loose on me..... Hope that helps.
Old 02-02-2013, 06:13 PM
Tom's Avatar
Tom Tom is offline
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Quote:
Welcome to FTE Justin!
Please remember to take a look at the date; deckpros posted this one nearly four years ago!
Sorry to hear about your sector shaft breaking, but I can't help but think that your lift and huge tires had something to do with it.
Old 02-02-2013, 06:44 PM
99f350sd 99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
Even with big tires this area should be strong enough..IMO. I have heard this happening quite a bit lately but still not enough to warrant any concern from ford.
Dick
F350 steering gear box problem? theonlypheonix 1999 to 2016 Super Duty 17 06-30-2015 05:55 AM
Steering gear box to tight? delliscoracing 1973 - 1979 F-100 & Larger F-Series Trucks 7 03-01-2015 10:31 PM
More steering box questions JoeJJones 1987 - 1996 F150 & Larger F-Series Trucks 12 09-30-2014 11:21 PM
'77 F250 hiboy 4x4 steering conundrum Kelticbear 1973 - 1979 F-100 & Larger F-Series Trucks 22 07-23-2014 11:52 AM
1961 Ford F100 Flareside 3 speed Column R. Victor 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 09-23-2013 01:16 PM
Tags
02, 08, 2002, 2008, 9903, box, duty, f250, f350, ford, issues, problem, problems, steering, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
