This truck will not downshift when you come to a stop. You must manually shift it all the way through and then it does fine. What is causing this issue? It will kick down into passing gear. Anyone know what is wrong?
You can also get codes using the appropriate scan tool. I have used a Snap-On MT2500 on these for many years. Also, here is a very inexpensive one that should work for you:
