70's vintage 8000 lbs Warn winch - Ford Truck Enthusiasts Forums
Old 03-25-2009, 11:07 AM
shack shack is offline
shack is starting off with a positive reputation.
Guys, I have been saving this old 70's model 8000 lbs Warn winch for just the right truck. Any tricks to bolting it up to the winch bumper? And does it matter if the cable comes off the top or bottom of the spool?
Joel
Old 03-25-2009, 12:02 PM
1977f150xlt's Avatar
1977f150xlt 1977f150xlt is offline
1977f150xlt is gaining momentum as a positive member of FTE.
i am not a expert on winches and i myself am interested in the same question, and if you don't mind could you post some pictures of the winch and the truck planned for it? if you don't know how to just click this link below its a thread i started awhile back
http://www.ford-trucks.com/forums/78...-pictures.html
-Brent
Old 03-25-2009, 12:14 PM
1977f250 1977f250 is offline
1977f250 is starting off with a positive reputation.
What model is it? Most Warns bolt to a plate from the bottom as do most other makers unless you have a 7284 and that will bolt to the face of the plate but is the fastest winch Warn ever and still makes.
Old 03-25-2009, 07:34 PM
matt's77 matt's77 is offline
matt's77 is starting off with a positive reputation.
All the winches I've had or seen have had the cables come out of the bottom. You should be able to tell when you let it out or real it in. I have used battery cables to check if the winch works. So you could do that to see wich way the cable reals up.
There will be four bolt holes on the bottom of the winch. Just use some grade 8 bolts that fit and bolt to the bumper. Power cable goes to battery, find a good ground spot and you are good.
Old 03-25-2009, 11:49 PM
I think I would bolt it to a lot more than the bumper, well in less you don't like your bumper, and get yourself a ****** block to go with it. It will have a lot more pulling power with it. If you really get stuck I mean deep or in a place where you may have to drag your truck out it will really help there as a 8000# is really a light winch for one of these trucks.
Old 03-26-2009, 08:08 AM
lostinfords's Avatar
lostinfords lostinfords is offline
lostinfords is starting off with a positive reputation.
Here is a pic of the winch and winch bumper from the 76 F250 that I bought in 1983, sold the truck but kept the set up to put on every other truck I owned, at present it sits on my 79 supercab, notice how the brush guard has the cut outs/protectors for the turn signals on the top and the headlights on the bottom, to correlate to the 76 model year. The cable comes off the bottom, if I remeber right it is a model #8274, it has been very faithful over the years. I also have the same model w/ a different bumper set up from my 74 crew cab.
Here as a pic of the 74 set up
Old 03-26-2009, 08:09 AM
this is the brush bar set up that goes w/ the 74 bumper set up
Old 03-26-2009, 06:22 PM
chapinmesa's Avatar
chapinmesa chapinmesa is offline
chapinmesa is starting off with a positive reputation.
Lucky you have that winch. I have a '70 highboy, and the push bumper even has a plate welded on where it looks like a winch once was, winches come in pretty handy
Old 03-27-2009, 03:15 AM
Thanks!!!!!
Get a WARN Winch Starting at $399 Warn Industries Vendor Specials, Discounts, Product Announcements & Group Buys 0 08-04-2016 02:00 PM
Ye' Olde Wench & Trinkets for the F-250-SD Thomas White 1999 - 2003 7.3L Power Stroke Diesel 32 09-14-2015 10:17 PM
Warn vs. Ramsey iggybob44 Offroad & 4x4 26 09-06-2011 10:42 AM
Hiden winch mount woody367 1999 to 2016 Super Duty 5 05-05-2010 10:56 PM
What would you do with an 8k lb truck and a 9k lb winch? Robert6401 Offroad & 4x4 11 08-23-2009 02:06 AM
Tags
1979, 70s, 8274, back, bumper, bumpers, f150, ford, fseries, older, parts, trucks, vintage, warn, winch, winches
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
