Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 03-25-2009, 02:09 AM
JaysRanger JaysRanger is offline
1998 Ford Ranger
My Garage
JaysRanger is starting off with a positive reputation.
1998 ford ranger red hot
i got a 1998 ford ranger with a 2.5 and the exhaust manifold get red hot after running for a while. does anyoine know what will cause that maybe a clogged cat?
  #2 (permalink)
Old 03-25-2009, 10:40 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
Does the cat get excessively hot too? Seem like it's down on power? If so, that might be a possibility. Any codes, Check Engine Light on?
Might also be a bad fuel pressure regulator allowing excess fuel into the engine, that should trigger a code from the O2 sensors.
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 03-25-2009, 10:37 PM
1998 Ford Ranger
My Garage
i aint to sure about if the cat is getting hot. it has the check engine light on but every time it reads a iac overspeed... and i have notice a loss of power and mpgs... down to like 10 miles a gal.. which after the tires and lift it was only at 14-15 miles per gal..so but ill check the cat tom and see if its gettin hot if not maybe ill replace the fuel regulator. and its a real pain to get cranked but once it starts and runs for a min with me holding the gas it will do fine after that.. so im lost on this stuff..... and i do believe its running rich to so u know im gonna get one tom. and put it on and see whats happens thanks
  #4 (permalink)
Old 03-26-2009, 02:58 PM
jimdandy jimdandy is offline
jimdandy has a good reputation on FTE. jimdandy has a good reputation on FTE. jimdandy has a good reputation on FTE.
If the CEL is on, I would have the codes read instead of throwing parts at the engine hoping for a fix. Expect a 02 code which may or may not be part of the problem.jd
__________________
In memory of my beloved Sandy, 9/28/53 - 1/24/03
  #5 (permalink)
Old 03-26-2009, 10:23 PM
1998 Ford Ranger
My Garage
i have ran the codes and like i said IAC overspeed error. is the only code it brought up.. which a while back when a ran the codes at the start of all this it brought a o2 code and replaced the back when and aint got it again... and the only other code it ever brought up about 4 months ago was a egr code cant rember which oine.
  #6 (permalink)
Old 06-14-2009, 12:52 AM
Traxxis's Avatar
Traxxis Traxxis is offline
1994 Ford Ranger
My Garage
Traxxis has a very good reputation on FTE. Traxxis has a very good reputation on FTE. Traxxis has a very good reputation on FTE. Traxxis has a very good reputation on FTE.
When you say a loss of power... does it just become a real dog? Or is it just a bit of lost power?
Check the cat. If it's glowing red-hot... it's running rich. When mine did this, it ran like a real dog... but only 1/2 the time. I eventually changed the ignition control module (after busting the cat out to determine it wasn't clogged)... and it ran great every since.
Stan
__________________
'94 Ranger XLT Ext. Cab 3.0L 5-speed
'97 Ranger XLT Ext. Cab 2.3L 5-speed
  #7 (permalink)
Old 06-14-2009, 07:11 PM
1998 Ford Ranger
My Garage
well it does it mostly when i first start it it wont have enough power to start moving... i don't have a cat anymore due to this reason.. but once its gets going it only runs like 60...70 at the most. and it used to be quick
Tags
1998 , 1999 , 23l , 25 , 97 , 98 , exhaust , ford , glows , manifold , models , power , ranger , red , speed , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
