85 knock sensor
85 knock sensor
I've got an 85 F-150 w/302FI. It does have a knock sensor, I have it in my hand but I can't find reference for in in the haynes for that year and the parts store doesn't show it as being on that year model (or even the years it is shown in the book). I get the knock sensor not found (25) code when I run the codes. I found the wire dangling and the sensor broken off. Does anyone know a part number / store where I can get one of these. thanks
Knock knock
knock
Did ya try the junk yard dont look like theres a lot that could go wrong and I bet it would only be a few bucks and its the same part on a crap load of them
knock
I dont know but Autozone and shucks shows the one for my 85 f150 5.0 and its on the drvers side of the lower intake just above 3-4 intake botles and my 90 donar e150 5.0 is on the pass side of the block right behind the intake
I stopped at autozone yesterday and they couldn't even order it. I found it at the dealer for $88. I know the motor has been changed, suppose to be a crate motor about 8k ago. The computer is giving me a code for it so I assume that it is suppose to be there unless they changed the computer too. How can you check to see if it is the computer that is suppose to be in it?
on
A knock sensor, IIRC, produces voltage when a knock (detonation) is "heard". The comp retards the timing until the knock goes away, so I cant see how your engine could run smoother with a new knock sensor unless it was too sensative to knocking (unlikely), then unplugging it would have the same effect.
I pulled it took the number to Autozone, it was the first one he pulled up for the 85 so I guess it's right. I think I may just have other problems besides the computer, got to keep looking. THANKS
