Extra-capacity fuel tank
The rear tank is leaking (corrosion) on my truck, so I thought that I would look for an extra-large tank that would fit easily where the rear (original) was. I found this one,
77 Ford F150 1/2 Ton Pickup Truck 38 Gallon Extra Capacity Gas Tank > LMC Truck > 38 Gallon Extra Capacity Gas Tank For 77 Ford F150 1/2 Ton Pickup Truck
Has anyone tried this? Thought maybe the frame rails were too close together on a 92' as opposed to a 79'?
I will have to find out if #1, it would fit on a 1992 F-250, and #2, if it was fabricated from a material that was compatible with diesel.
If the tank fits between the frame rails, the filler neck and sender hole are the same size and are located in the same places, we should be in business!
Danspeed1
16
12-21-2009 02:41 PM
Kleenax
16
06-18-2009 05:19 PM
archangel
10-17-2007 09:41 PM
fozzy
11-11-2002 12:17 AM
