What is the firing order for a 2001 Ford F-150 4.2 engine.
Old 03-24-2009, 05:06 PM
samoanbuilt's Avatar
samoanbuilt
samoanbuilt is offline
Post What is the firing order for a 2001 Ford F-150 4.2 engine.
I've just bought a new ignition coil to replace the last once which I replaced about a year ago. I didn't do the replacemnt for the last one so I wanted to make sure that I had the right wiring order from the coil to each spark plug. Does anyone know where I might be able to find a wiring diagram for 2001 F150 4.2 V-6?
Old 03-24-2009, 06:07 PM
Ron W.'s Avatar
Ron W.
Ron W. is offline
Old 03-24-2009, 07:43 PM
samoanbuilt
Actually I did Google this topic and it got me that exact link. I'm not sure but I believe those numbers represent the firing order of each spark plug. Unfortunately I need to know how the plugs are numbered on the engine as well as the ignition coil so that I can match each coil to it corresponding spark plug.
Old 03-24-2009, 10:00 PM
Ron W.'s Avatar
Ron W.
Ron W. is offline
Fan
4 1
5 2
6 3
Old 03-25-2009, 03:06 PM
samoanbuilt
Thanks for the info Ron. You wouldn't happen to know the corresponding order on the ignition coil pack?
bearsfan394
1997 - 2003 F150
02-13-2017 01:27 PM
Wildwes94
1997 - 2003 F150
02-02-2017 01:26 AM
Tyler Roberts
1997 - 2003 F150
09-22-2014 12:40 AM
hockeykev
3.8 & 4.2L V6
12-02-2007 10:09 PM
blue67stang
1997 - 2003 F150
01-06-2007 05:44 PM
Quick Reply: What is the firing order for a 2001 Ford F-150 4.2 engine.
