Newbie to the SuperDuty. How does the ESOF locking hubs work in Auto mode? - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-12-2009, 02:40 PM
triskit16's Avatar
triskit16 triskit16 is offline
triskit16 has a very good reputation on FTE.triskit16 has a very good reputation on FTE.triskit16 has a very good reputation on FTE.
I think guzzle has tried it before but I dont know about his success or whatnot. Shoot him a PM or email and ask him. Hes a great guy. Pointed me in the right direction to which spray lube to "unfreeze" my auto/manual dial. (DuPont Teflon spray lube)
Old 04-14-2009, 07:45 PM
iron1951 iron1951 is offline
iron1951 is starting off with a positive reputation.
I have still left the hubs in auto and when I turn the switch on the dash to 4x4 the front drive shaft turns. When I turn it to 2x4 the front drive shaft does not turn. I know this because my wife was driving and I stood outside the truck and watched the shaft. The only thing I have not done yet is to vacuum test each side and make sure that they are both working but i looks like the vacuum latches and unlatches the hubs in Auto as designed. When I took the hubs apart for cleaning I did notice that one latching mechanism was hanging up on one of the two stainless prongs. A little bending with the needle nose made sure that there was no hang up.
If you are trouble shooting if you have the two plastic pieces with the spring inside in your hand, one squeeze should lock the assembly together which would simulate the vacuum and diaphram squeezing the plastic together to unlock the front drive shaft by moving the outer steel gear outboard.
If you squeeze the two plastic pieces together again they should now come apart so that the spring can be removed. This second state of the latch would simulate the vacuum and diaphram squeezing the plastic together to lock the front drive shaft by moving the outer steel gear inboard as the spring expands and engaging the teeth.
Hope I have explained it properly to those who are having difficulty getting their front axles to free wheel in Auto.
Old 09-03-2010, 05:15 PM
Trustee Trustee is offline
Trustee is starting off with a positive reputation.
How the Latch Works
Iron, I believe you are the only one here who has asked questions about the internal operation of these hubs. I, too are very curious about how these operate.
You describe an action similar to the ratcheting of a retractable ball point pen -- where one "click" holds the plastic unit together and the next click releases it.
That would be fine, but how does that account for a strong (45 second) vacuum signal latching the hub and a weak (15 second) one unlatching the hub? If the hubs operated as you describe, how would the thing differentiate between a "latch" and "unlatch" pulse?
Anyone else have any thoughts on the internal workings of that little plastic/mental latch?
Old 09-04-2010, 09:19 AM
Trustee, I never thought about the two different signal pulses but here is my guess. The strong pulse is probably to latch and the weak pulse is to unlatch. If for some reason one side does not latch, then the hubs would be out of sync. If the vacuum pulses were the same then the hubs would be out of sync for a long time. With the two different pulses, one to latch and one to unlatch, the hubs could be synchronized quickly.
Some hubs are only automatic. The dial does not turn. If these hubs were out of sync, you would have to take the hub apart and manually synchronize it with the other side. Thats my guess for the two different pulses.
Old 03-01-2012, 11:11 PM
sxrsist sxrsist is offline
sxrsist is starting off with a positive reputation.
yes i am really thinking warns might be the answer.
Old 03-02-2012, 07:02 AM
A Challenge
I looked at these things as a challenge on my 2000 Expedition. They weren't locking/unlocking properly.
The first thing I tested was the vacuum source -- and that worked properly.
Then I put a handheld vacuum pump on each hub and found that one was leaking vacuum. It was, of course one that I paid to have the hub bearing replaced.
Well, I took the whole thing apart, cleaned everything up, replaced those very expensive seals, and now it holds vacuum and works perfectly.
The job was easy, if not a little heavy, but satisfying to get the whole thing working as designed.
One thing I should mention is that these things don't engage/disengage immediately. The wheels should be turning while the vacuum is being applied. If you just jack up one side and apply vacuum, it may or may not work. The wheel should be rolling to get a good idea of the performance.
Old 12-17-2013, 08:48 AM
billium's Avatar
billium billium is offline
billium is starting off with a positive reputation.
What does "ESOF " stand for please?
Old 12-17-2013, 09:03 AM
Pikachu's Avatar
Pikachu Pikachu is offline
Pikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud of
Electronic Shift On the Fly.
Old 04-22-2014, 02:22 PM
ed dennison ed dennison is offline
ed dennison is starting off with a positive reputation.
New to the forum so beg pardon I'll jump in. When the auto-lock hubs are set to auto, and the esof switch is set to 2wd, should the axle shafts turn when the truck is moving? The drive shaft to the front diff. is not turning, But the axle shafts are. Thanks in advance for any reply.
2003 f350 Lariat fx4
v10 , crew cab
2015 2016 2017 f150 4x4 system biz4two 2015+ F150 13 11-13-2016 07:26 PM
Removing Axle Shaft to Replace IWE Solenoid formula74 2004 - 2008 F150 5 05-01-2016 08:11 PM
Turning off the auto locking hubs porthole 6.7L Power Stroke Diesel 15 12-21-2015 08:31 PM
ESOF and OEM Auto-Hub Operation agsmv1 Excursion - King of SUVs 4 06-04-2015 03:45 PM
Overview of 4wd mscott 1999 to 2016 Super Duty 3 04-22-2015 05:24 PM
Tags
2002, auto, duty, esof, f250, fix, ford, front, hub, hubs, lock, locking, sd, super, superduty, vacuum, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
