1966 f-350 rack truck
Two squirts from an oil can.
If the compression comes up substantially, that would indicate bad rings. If it only comes up a few pounds then it is most likely a valve.
Also, to isolate the leakage (compression loss,) you can put that cylinder at it's top dead center position and put compressed air in the spark plug hole. The you can listen to see where the air is escaping. Intake, exhaust or crankcase, the sound should give you a pretty conclusive answer.
Michael Mehegan
1999 to 2016 Super Duty
01-17-2016 09:18 PM
tnfarmer67
09-05-2010 02:56 PM
Varqanir
10-14-2009 12:50 AM
