4" Dropped Axle ... Anybody Running one?
Old 03-24-2009, 12:24 PM
53OlderThanMe's Avatar
53OlderThanMe
53OlderThanMe is offline
I have a chance to buy a 4" dropped axle for a great price. I'm concerned about too much drop. I have stock springs but based on my measurement a 4" drop would put my axle to ground clearance at about 2" with my current tires. Current tires are fairly low profile and junkers so I could easily raise it to 3".
Just curious if anyone on here is running a drop this low and how they feel about it.
Thanks
Old 03-25-2009, 05:53 PM
53OlderThanMe
Ok, so I bought it for $150 but it appears to me to be a 2" drop not 4". He was measuring the actual drop at 4.125 and calling the original a 2.125" drop. Anyway appears to done at Mor Drop in CA. Came complete with brakes, springs, tie rod, drop ends for the tie rod, draglink and pitman arm. So looks like I can recoup my investment and then some along with a 2" drop.
Old 05-29-2017, 09:22 PM
Pete Usher's Avatar
Pete Usher
Pete Usher is offline
1963 4
Thanks
hi, I ran a mor-drop 4" drop on a daily driver from 1991 till 2015,,, I had no issues beyond catching a trash bag once in a while... that said I had all sorts of issues with the dropped tie rod ends and the tie rod.... at the time they had a cheap cut , dropped and welded tie rod end,,, and it broke at 70 mph,,, that was 6 years into driving it,,,,lmao when I heard something dragging I wiggled the wheel,,, as you know the stock box steering connects directly to drivers wheel,,, and as i heard dragging and figured that only the drivers wheel was steering I used the e brake to come to a stop... than the gf tried to run over me as I man handled the passenger wheel to turn the truck off the road,,,,, ahhh the fun of hot rodding....
I got 2 mor-drop axles over this time, the second came with elongated shock holes and warped king pin hole. ,,, so I had to get it machined.
make sure you get decent not some home brewed drops for the tie rod ends!!!
flhx06
15
12-26-2017 03:16 PM
724shovelhead
10-30-2017 03:54 PM
That 350 Guy
1999 to 2016 Super Duty
04-17-2017 12:49 PM
filthy6
02-14-2017 08:46 PM
carlhwv
10-29-2016 08:00 PM
Quick Reply: 4" Dropped Axle ... Anybody Running one?
