WAFTE Archived Buy/Sell/Trade ADs
That's right, this is the sales center of Washington State!
Chapter Buy/Sell/Trade Ads: Each chapter will have one (1) thread for chapter members to list items wanted, for sale or for trade. The rules for posting in this thread are as follows:
WAFTE achived buy/sell/trade ads
- Only Ford truck related items and automotive tools & equipment can be listed.
- Only one picture is allowed per post, per item. If additonal pictures are necessary, place a link in your post to those pictures. Additional posted pictures will be removed without warning.
- You must have your private messaging (PM) turned on and be able to receive PM's to post an ad in the Chapter thread. If you do not, your post will be removed.
- Use the PM or email system to conduct all discussion and transactions regarding the item(s). You can post your interest in the item(s) and that you’ll contact the seller but no discussions. Keep it short.
- If you post an ad, please reply that you found, sold or otherwise disposed of the item.
- The buy/sell/trade thread will be purged periodically for old postings. Generally every 30 to 60 days.
- You need to be an active Chapter Member on FTE to post a wanted, for sale or for trade item(s). No Exceptions.
- You must have permission from the Chapter Leader or a Regional Moderator to post an ad in a chapter that you are not a member of.
- If you are new to FTE (less than 15 days) or have less than 25 posts, you must contact the Chapter Leader for permission before posting an ad.
- Your ad or reply to any ad is subject to editing or deletion at discretion of the Chapter Leader, Moderators or Administrators of FTE.
- Commercial advertisements are strictly prohibited.
265/70/R17 PIRELLII SCORPION TIRES FOR SALE. TOTAL OF 5 (SOLD AS SET) 4 HAVE 16,5K MILES, SPARE HAS 0 MILES. UPGRADED MY TIRES AND DONT HAVE ROOM TO STORE THE OLD ONES. ASKING $770 OBO.
CELL: 425.350.1976 ASK FOR JORY.
THANKS.
JoryLee
IM LOCATED IN KITSAP COUNTY AND PICS TO COME SOON.
THANKS.
JoryLee
I have a 351 Windsor In my 64 f250 I would like to trade for a 64ish 292. These would need to be swapped and I don't have equipment but may be able to acces some. There is nothing wrong with the Windsor, I am just trying to resort the truck to original condition or as close to it as I can. email me if you want some more information.
265 70 r17 tires for sale
this is an updated post with pics to the prior post I have up. sorry for the double post.
THANKS.
JoryLee
IM LOCATED IN KITSAP COUNTY. This is the only pic it will let me post do to prior posting. I have more pictures if your interested. Thanks
THANKS.
JoryLee
I have several items to sell, the first one is diesel only, the rest will work for diesel or gasoline engined trucks
1) I bought this 2WD S42 ZF-5speed last summer when I was looking at doing the swap in my truck. That was before I found out that you CAN'T just swap out a tailshaft housing (like on my old T-19) and convert it for use in a 4WD.
So anyone looking for a 2WD ZF-5? As mentioned before, it is an S42 model with the following gear ratios
1 -- 4.65
2 -- 2.60
3 -- 1.53
4 -- 1.00
5 -- .077
R -- 4.35
Looking to get $600 for it - which is a steal since I've seen them sold for nearly twice that much
2) I also have a good model 1345 transfer case WITH the "push down" typoe shifter on it. Will fit behind any T-19 or ZF5 speed. Best (reasonable) offer.
3) For those with a T19 and 3.08, 3.55 or 4.10 gears who want some lower gears for 4-wheelin or towing, I have an Advance Adapters Ranger Gear Spiltter. 17% underdrive. Basically the same effect as being able to switch your axle gears from 3.08 to 3.60, or from 3.55 to 4.15, or from 4.10 to 4.80 - on the fly - any time - and in any gear, because it is a fully syncronized box! It comes with shortened rear and lengthened front driveshafts to fit a standard cab standard bed truck and a heavy duty crossmember to go with it. This will work with a 2WD or a 4WD. Looking for $600 for the whole setup (Ranger, shifter, drivelines, and crossmember)
4) T-19 four-speed tranny. This is the close-ratio unit out of a diesel, and it comes with the diesel bellhousing. I took it out of my truck when I did the ZF swap last summer. You can change the bellhousing and put it on a gasoline powered truck, but the bellhousing it comes with is for a 6.9 or 7.3 diesel. It needs a new input bearing - about a half hour job and a $30 part. Asking $250 for it as is, or I can install the new input bearing for you for an extra $50.
Lastly, I am also looking for a pair of budd - wheel adapters and 3 budd wheels for the front of my dually (3rd wheel as a spare), so if anyone who's interested in any of the items above and has the wheels and.or adapters, we can talk trade + the difference in cash...
1 -- 4.65
2 -- 2.60
3 -- 1.53
4 -- 1.00
5 -- .077
R -- 4.35
I'm getting a bunch of stuff together here, ready for sale. Most of this stuff will be up for grabs in a couple weeks:
300-6 engine, about 20k on it, DUI distributor. Block and head are 1980 parts, 8.7:1 compression, non-emissions cam. Ford 1BBL carb. $200
C4 auto, small block bell, fixed yoke, needs rebuild. $100
D60 full float rear axle, 4:10 gears open diff, $150
Mint 67-72 dash pad, black, $150
Near-mint 67-72 dash pad, some very slight damage to the speaker grill area but otherwise perfect, $100
68-72 interior door panels, $20 each
67-72 manual steering box, I have two of them, $50 each
Very nice 72 blue bench seat, comfort-weave vinyl, $50
I have a bit of a surplus of 68-72 odds and ends, -maybe- some body parts but no fenders just yet, and no tailgates. I do have a cool set of split rims, though.
A few more things to add:
Ramsey 8000lb PTO winch, the drum flange has some damage from having way too much cable on it, but comes complete with driveshaft, control, and PTO box that bolts on the side of the tranny. $350 takes it all
Near-mint blue 67-72 dash cover. Has two small fixable holes in the top, looks like someone mounted a CB there, but otherwise excellent and the rare medium blue color. $100
Set of four 16" eight lug split rims. Seem to be halfway decent, I don't want them though. Trade for set of 16" or 16.5" eight lug steel rims with some sort of tire on them.
Compass Canopy
Looking for (2) original 1973-79 Ford Compass Canopies for my truck and trailer. Also, looking to swap my white trailer bed for a bed with the same color scheme as my truck.
