WAFTE Archived Buy/Sell/Trade ADs
#497
The last composite headlights I got were for an F350. This cost about $45~$50 if I recall right. I got them from
I-5 Auto & Truck Parts
190 Estep Rd Chehalis, WA 98532, United States
(360) 262-3550
https://plus.google.com/105821451388...ut?gl=us&hl=en
They are a B&R not but were easy to deal with and have trucks.
Sean
(360) 262-3550
Sean
#500
Got a Ford 9" rear ring and pinion set. 4.57:1 ratio, ORIGINAL FORD ring and pinion set. Less than 1000 miles on it. Used for one summer in 1974 and been in storage ever since. Here's the craigslist ad for it. Still in it's original box.
ORIGINAL FORD 9" 4.57:1 RING AND PINION
#502
I need a pair of 390 rocker oil baffles. I had to rob them to put in my 352. Seems when whoever rebuilt the 352, the deflectors weren't used. Also if anyone has an FE timing cover set with repair sleeve that would be great. Actually I could use a Full gasket set also. Thanks
#503
My two car garage is already so full I can only get the Mini
in it and still step over things to get at all 4 corners. Well sort of.
Hot car. After the 2001 garage fire. Yes that is the back end but it sure looks like a mean mouth full of teeth
BTW that WAS a Toyota Solara. One really nice car. The only small car I have driven that was quiet on the road.
My hyper hearing. Road noise Makes my ears hurt. No BS. Real pain.
A chair ,Diet Coke and some Deep Woods OFF for the mosquitoes. If you look at this as think I have
room for more. This was after I moved things out to work on the truck.
Sean
#504
#507
I think I still got a stock air filter housing off a 87 460. No idea if the air door mechanism still works.
#508
If you have a vacuum pump/tester you can test if the diaphragm canister is still good. Also could probably take a heat gun to the thermostatic switch to see if it does anything. If it does work. Do you happen to have any pics of it?
#510
Looking for shop equipment either cheap or trade for Part, Labor or Hauling or whatever.
Looking for a Large Air Compressor either 220v or 110v prefer 50 gallon or bigger.
Hydraulic Tubing Bender.
Press that's 10 Ton or better.
Drill Press that's a Floor Model.
Metal Lathe.
Sand Blasting Equipment.
Large Tool Boxes and/or Steel Workbenches.
Tools of all kinds: Air, Electric, Jacks, Stands, Power, Hydraulic, Specialty etc etc etc.
Metal Lathe.
