Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 03-23-2009, 09:47 PM
bismic's Avatar
bismic bismic is offline
bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold
More injector info .........
Credit for the first two paragraphs belongs to Josh Boggin (River City Diesel):
The main reason why the 6.0 is so picky about oil is because it is totally reliant on two electromagnets to shuttle the spool and control the oil to the injectors. The 7.3`s use a electromagnet also but a spring to return the poppet to the closed position. Obviously the spring will work much better to "cut" through the thick oil and close the oil flow.
Not only will running oil with too thick of a viscosity cause rough starts. But this also will interrupt the shuttle action of the spool causing injection timing to be retarded causing poor performance and decreased mileage until the oil is up to full operating temperature.
I "stole" it from another site. I thought it was worth sharing.
I also wanted to consolidate some info from another post for all those "future" members using the search function:
Common Symptoms of failing injector(s):
Hard Starting (especially w/ cold engine)
Excessive Smoke (white or bluish white)
Rough Running
Low Power
Stalling
Misfire
Buck / Jerk
Typically when one injector fails, the engine is hard to start and is low on power. If two injectors fail starting will be very hard or the engine will not start at all. If you do manage to start the engine, it will be very low on power.
Diagnostic Tips:
  • Before beginning any diagnosis or parts replacement, always determine if your truck's PCM and IDM (Injector Drive Module) have been updated to the latest software. Recent changes correct hard cold start/cold smoke/poor cold running issues by energizing the injector coils during glow plug operation in order to heat the oil in the injectors. Software is VERY important to 6.0L operation.
  • If oil is very dirty, change it and see if operation improves.
  • The 6.0L has many issues with electrical harnesses rubbing through - even the updated harnesses. The injector harnesses can rub through near the valve covers and either prevent an injector from firing or cause it to stay on all the time.
  • Any time a 6.0L develops a stalling or a miss, check the problem out right away to prevent possible further damage!
Video on Bad Injectors:
Besides design issues, the #1 cause of 6.0L injector failure is poor maintenance! Because engine oil at very high pressure is used to operate the injectors, keeping the oil clean is absolutely essential to maximum injector life.
Besides keeping the oil clean, fuel is the next major issue that affects 6.0L injectors. Poor quality fuel with water or dirt in it is absolutely deadly to your injectors. Also, because the fuel actually provides a cushion for the internal valving of the injector, anything that causes low fuel pressure will kill the injectors. This includes not observing proper fuel filter maintenance. Fuel filters should be serviced at a maximum of 15,000 mile intervals (10,000 miles under extreme service). Low pressure caused by a failing fuel pump can cause repeat injector failure. ALWAYS check fuel pressure after installing new injectors. Use manufacturer's spec for your truck, but generally look for around 60-65 PSI with the engine running. Finally, running a 6.0L Powerstroke out of fuel is deadly to injectors! On early trucks, if you run out of fuel, you will usually be buying 8 injectors. If you think you are going to run out of fuel, stop, shut the truck off, and walk. It may save you $2,500. Later trucks have a PCM strategy which limits pressure to prevent injector damage during a low fuel condition, but it is still a situation to be avoided at all costs.
Good article on Fuel Pressure:
http://fordpowerstrokeforums.com/downloads/Fuel-Pressure.pdf
Also -
Might want to read those stickers on the engine and read the book where it says to NOT use starter fluid, thats a really good way to damage your engine, it leaves fairly telltale signs that makes it real easy to void engine warranty. The other thing to keep in mind is that the injector tips are actually cooled by the fuel passing through them, so if you put the ether to it the injectors can overheat resulting in plunger scuffing and injector failure.
Video on draining your fuel tank (if you happen to fill it w/ gas)
", back and forth, on and off every time the injector fires. Many factors play in to how well that valve works such as, oil temp, oil quality, normal wear, ambient temp, and many others. As this valve ages it polishes itself inside the bore of the spool valve and as the spool valve slams back and forth it can set up the condition like a suction cup, hanging the valve to one side or the other. This uncommanded uncontrollable condition is called stiction. Mostly its a rough run cold condition but in severe cases it can be a no start or pretty harsh misfire condition. Oil that stays inside the valve on a hot engine shutdown and is allowed to cool slowly in the injector can aggravate the condition on restart, so the newest reflash uses inductive heat after shutdown to keep the oil warm, keep its viscosity low, and maximize the oil flowability to purge the oil from them. It has worked fantastic. It is an excellent preventative measure.
Summary:
Prolong Injector Life:
Change fuel filter at 10,000 miles, use OEM style filters
Good quality fuel - purchase at high volume stations
After filter change, remove air before starting: 3 cycles of (ignition on for 3 sec, ignition off for 15 sec).
Then ignition off for 3 seconds and START.
Find a good additive for lubricity and in event of getting bad fuel (w/ water, low cetane, additives not added, etc).
According to the manual - use an additive when suspect fuel quality problems : non alcohol, water demulsifier
Good links on Additives:
Do diesel fuel additives really Work? How and Why ! - Truckinfo.net
http://www.johnfjensen.com/Diesel_fuel_additive_test.pdf
Do not run your tank empty (below 45 psig fuel pressure ruins injectors)
Install a fuel pressure gauge with an alarm point you can set. Stop if it drops below 45 psig
Biodiesel is a great lubricity additive, just remember it can gel. Use an antigel additive, especially in winter
Mods -- ITP Return Regulated Fuel System (equal pressure to all injectors), FASS System - pressure control, air removal, also Air Dog w/ Raptor pump.
Early Injectors: (White Top)
Ford Part Number: 3C3Z-9E527-AE
Fits 2002.5 - 2003 Ford Powerstroke 6.0L
International Part Numbers: 1843089C91, 1845879C91, 1843481C94, 1843481C95
Fits 2003 - 2004 International VT365 6.0L
Late Injectors: (Black Top)
Ford Part Number: 4C3Z-9E527-AA
Fits 2004 - 2006 Ford Powerstroke 6.0L
International Part Numbers: 1844751C2, 1846692C92
Fits 2004 - 2006 International VT365 6.0L and VT275 4.5L
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; Line-X; CPOhighway Products tool box; tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox; Re-flashed; Fuel Pressure gauge; DashDaq on deck
  #2 (permalink)
Old 03-23-2009, 09:54 PM
juneau76's Avatar
juneau76 juneau76 is offline
2003 Ford F-250
My Garage
juneau76 is gaining momentum as a positive member of FTE.
Mark, you never cease to amaze me with your research and knowledge. Great info! Perverbial reps to you since I need to spread the love around. Thanks.
__________________
Brad
2003 F-250 Lariat Supercab 4x4 6.0L PSD, Fumoto, Updated HFCM Plug, DieselSite Bypass Coolant Filter, 22" Wiper Blades, more to come...
2008 Taurus X Limited AWD w/ a Fumoto (The Wife's Family Truckster)
Quote:
You haven't lived life until you've done 110mph in a Yugo
  #3 (permalink)
Old 03-23-2009, 09:59 PM
SteveBricks's Avatar
SteveBricks SteveBricks is offline
SoCal Chapter LDR
2006 Ford F-250
My Garage
SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation
Thanks for another great post, Mark.
__________________
NHRDA #4698
SoCal FTE
Join our Chapter *HERE*
9/21/54 - 9/25/09
  #4 (permalink)
Old 03-23-2009, 10:17 PM
bismic's Avatar
Here are four videos I found interesting:
Driveability concerns that lasts 3-5 minutes on cold start-up):
mms://multimedia.ford.com/seopts/Tech25_250k.wmv
Injector Diagnosis
mms://multimedia.ford.com/seopts/Tech12_250k.wmv
6.0L Fuel & High Pressure Oil Sub-System Diagnostics
mms://multimedia.ford.com/fordstar/61914.wmv
Miscellaneous: Stiction, Injector Buzz test, Diagnostics, etc
Also - link to "Injector Balloon test"
http://www.ford-trucks.com/forums/799530-how-to-test-ipr.html
__________________
Mark
  #5 (permalink)
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
Big J
2005 Ford F-250
powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of
Great post Mark! As usual. I tried to rep 'ya but I've got to spread the love some more first. Kudos!
__________________
John
2005 F-250 SD Lariat CC 4x4 6.0 TS Auto.
2007 GMC Yukon Denali
  #6 (permalink)
Old 03-23-2009, 10:19 PM
1bddelx's Avatar
1bddelx 1bddelx is offline
1bddelx is starting off with a positive reputation.
Great info. Thanks
__________________
2006 F-350 CrewCab Longbed 4x4 PSD
8" ProComp Lift With 37x13.50x18 Skins
Airbags
Banks Exhaust
Afe Drop In Filter
Tows A 36' 5er Lifted Also
  #7 (permalink)
Old 03-23-2009, 11:05 PM
bismic's Avatar
A little more consolidation ..........
The difference between original C94 & new C95 was internal change to clevis. Had to do with plunger suffering from side loading which then causes raw fuel to flood and enter the engine oil crankcase. Design improvements aimed at preventing scuffing.
There are no physical fitment differences between the injectors, but I would not intermingle them.
Along with the clevis re-design mentioned above (which helps prevent scuffing) one additional change below:
Change in 2004 from the 2003 design:
DLC (Diamond Like Carbon) Coated Plunger
• The injector plunger has had a DLC coating applied to it
• The coating will further increase the robustness of the injector against poor fuel quality/water intrusion and will reduce the risk of internal scuffing.
Note: This injector has different operating characteristics and can not be interchanged with non DLC injectors.
Installing the incorrect injector could cause Erratic or rough engine operation.
__________________
Mark
  #8 (permalink)
Old 03-23-2009, 11:31 PM
bismic's Avatar
tsb-06-2-13
tsb-06-2-13
IF THE VEHICLE RUNS ROUGH OR HAS A MISFIRE WHEN THE ENGINE IS AT OPERATING TEMPERATURE, DIAGNOSE THOSE CONCERNS BEFORE PROCEEDING WITH THIS TSB.
http://www.ford-trucks.com/tsb/fullt...hp?tsb=06-2-13
__________________
Mark
  #9 (permalink)
Old 03-24-2009, 08:14 AM
bismic's Avatar
I found this in a recent search ,,,, The above TSB has been replaced w/ the TSB (tsb-08-26-03) in the link below:
http://www.justanswer.com/uploads/ti...sb08-26-03.pdf
Taken from the link above:
Some 2003-2005 Excursion, 2003-2007 F-Super Duty and 2004-2009 E-Series vehicles equipped with a 6.0L diesel engine may experience no starts, hard starts or rough running when cold and may be accompanied with diagnostic trouble codes (DTCs) P0611, P1378 and / or all 8 injector circuit codes. These symptoms may lessen or disappear when the component engine is warm. These conditions may be caused by the Fuel Injection Control Module (FICM) or injector spool valve sticking internally during cold engine operation.
An improperly operating vehicle battery(s) or charging system can cause additional operating loads to the internal components of the FICM module, due to low power supply voltages. Glow plug operation, vehicle accessories (factory and non-factory installed), and hot and cold temperatures can also put additional requirements on the vehicles electrical, battery and charging system. This can result in shortened FICM module life.
The FICM module contains two major internal components, the main circuit board and a DC-DC converter. The DC-DC converter is the device that amplifies battery voltage to 48 volts (V) to operate the injectors.
Not wanting to generalize or oversimplify, but it looks like many injector jobs in the past should have been FICM jobs!
__________________
Mark
  #10 (permalink)
Old 03-24-2009, 08:34 AM
brickie's Avatar
brickie brickie is offline
brickie has a very good reputation on FTE. brickie has a very good reputation on FTE. brickie has a very good reputation on FTE. brickie has a very good reputation on FTE.
Great post once again Bismic.Thanks
__________________
Tony 03/04 6.0L 350 Crew ,DRW,ZF-6, XLT fx4, EconoMax injectors, Autometer Fuel, Boost & EGT. Fass 95/90, Sct X-III with some sweet Spartan tunes, ARP studs, RR fuel system, Southbend FB8, Fluiddamper, Ali Arc hunting bumper,Light Force, Ride-Rite helpers,Ford APCM and some other stuff.
03 6.0L Ex LTD mostly stock motor and a bunch of bolt ons on the truck.
  #11 (permalink)
Old 03-30-2009, 07:48 PM
bismic's Avatar
More good articles:
http://www.fordtechservice.dealercon...l-Pressure.pdf
http://www.fordtechservice.dealercon...FICM_Guide.pdf
http://turbodieselforums.com/diesel_2.pdf
http://turbodieselforums.com/diesel_4.pdf
__________________
Mark
  #12 (permalink)
Old 03-30-2009, 07:58 PM
Big J
2005 Ford F-250
Great info once again Mark! I tried to rep you but I've got to spread some first. Catch you on the next round. Thanks again - another great post to bookmark.
__________________
John
  #13 (permalink)
Old 03-30-2009, 08:56 PM
bismic's Avatar
Page 51 - cylinder balance test (from Brickie)
http://turbodieselforums.com/downloa...004%20Book.pdf
__________________
Mark
  #14 (permalink)
Old 03-31-2009, 10:12 AM
brickie's Avatar
PowerStroke This one has the evolution of powerstroke injectors up to the 6.0L.
__________________
  #15 (permalink)
Old 04-03-2009, 09:33 PM
bismic's Avatar
I left this one out -
6.0L Powerstroke Injectors
__________________
Mark
Tags
082603 , 2003 , 2006 , 60 , 73 , f350 , ford , idm , injector , ipr , miss , mmsmultimediafordcomseoptstech12250kwmv , p0611 , pdf , tsb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
