Towing capacity and GCWR for a 1993 F350 dually - Ford Truck Enthusiasts Forums
Old 09-24-2002, 05:18 PM
doccherry doccherry is offline
doccherry is starting off with a positive reputation.
My owner's manual doesn't list the truck I have so I can't get the towing/carrying capacities. Also, the Ford research dept. told me that they would send me all the info but all they sent was a towing brochure for 2002 Fords. Here's what I have: 1993 F350 regular cab dually, auto trans, 460 engine, 4.1 axle. I have been pulling a horse trailer, which when loaded with horses and gear, weighs 5000 pounds. I use a weight distributing hitch. I have put a cabover camper on the truck and the camper weighs about 2100 pounds when loaded. The truck has a GVWR of 10,000 pounds and weighs about 8200 pounds with passengers, gear, and camper. I want to make sure that I can pull the trailer with no problems now. I'm certain I can, but I would like to get the numbers anyway. Does anyone know what the GCWR is for my truck? Any help would be appreciated.
Old 09-25-2002, 12:01 AM
qcbob qcbob is offline
qcbob is starting off with a positive reputation.
Old 09-25-2002, 10:39 PM
4x4x4x4 4x4x4x4 is offline
4x4x4x4 is starting off with a positive reputation.
Pretty sure it's about 10,000lbs.towing capacity.If I get a chance and remember I'll look in a 96 brochure and post it in the next few days.It should be about the same for both years.
Old 09-26-2002, 02:39 AM
dpoelstra dpoelstra is offline
dpoelstra is starting off with a positive reputation.
my '86 has a 13,000 towing capacity with the same setup.
Old 09-26-2002, 06:08 AM
DeenHylton DeenHylton is offline
DeenHylton is starting off with a positive reputation.
I have a 89 F250 which is equipped like yours(460, C-6, 4.10's, tow pack with super cooling) my owners manual states a GCWR of 18,500 lbs. and a max trailer weight of 12,500 lbs. You should be close to the same. The towing capacity between an F250 and F350 are usually within a couple hundred lbs. the big differance comes in the weight you can carry in the bed of the truck, with the F350 naturally being able to carry more weight. Deen
GCWR Determination texastech_diesel 1999 to 2016 Super Duty 31 08-15-2016 11:26 PM
Help Me Understand My Truck's Capabilities AKHunter93 1987 - 1996 F150 & Larger F-Series Trucks 27 05-09-2016 05:42 AM
Towing a car from Houston to LA Haestings Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing 20 10-20-2015 04:25 AM
Need a trailer to haul my truck cross country Jolly Roger Joe 1948 - 1956 F1, F100 & Larger F-Series Trucks 52 03-08-2015 07:56 PM
Too much camper?? cwilson285 Fifth Wheel & Gooseneck RV Towing 7 03-07-2005 09:05 AM
Tags
1993, 1997, 2002, 93, capacity, dually, f250, f350, ford, gcvwr, gvwr, max, specifications, towing, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
