Go Back   Ford Truck Enthusiasts Forums > Misc. > Towing, Trailers & 5th Wheels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Towing, Trailers & 5th Wheels SPONSORED BY:
  #1 (permalink)
Old 07-14-2002, 01:34 PM
highcountry highcountry is offline
Garage is empty, add now
highcountry is starting off with a positive reputation.
trailer axle identification
Hi,
I have access to a chassis with tandem axles that used to be an old 21' travel trailer untill a big tree landed on it. I was thinking about using the chassis as a bumper hitch flat bed trailer. The GVWR sticker is long gone unfortunately. I am trying to find out if the axles are worth saving. They carry an odd four bolt split rim wheel with reverse thread lug bolts on one side. The hubs are marked "DAYTON" and have the following numbers- W-2 and 9222 there is also a small indescernable number that I will attempt to make out if it would be helpfull. I would like to know what these axles are rated at and if there is any way to swap hubs to carry a centerless type wheel. Thanks for any information.
  #2 (permalink)
Old 07-14-2002, 11:12 PM
kbmc4 kbmc4 is offline
kbmc4 is starting off with a positive reputation.
Get your spindel meas. dia. how long and where the steps are call where ever you get trailer parts they most likley can get you hubs that fit your spindels you can have 2500# axles and 1500# springs so you need to look at them also.
  #3 (permalink)
Old 09-30-2002, 06:50 PM
jrshaw1 jrshaw1 is offline
jrshaw1 is starting off with a positive reputation.
Is it a split rim or is it a Fayette? Fayettes have about an 8" round center with 4 lugbolts, driver's side is left hand thread.
Any pics??
Jrshaw1
  #4 (permalink)
Old 09-30-2002, 09:57 PM
johnsdiesel's Avatar
johnsdiesel johnsdiesel is offline
johnsdiesel is starting off with a positive reputation.
__________________
1997 F250 HD PSD SuperCab 4X4 ZF5 4.10
173K miles
CMP Info1
CMP Info2
  #5 (permalink)
Old 03-27-2006, 02:27 AM
bprea bprea is offline
bprea is starting off with a positive reputation.
Hi, I was searching for a new fayette rim and hub because I ruined mine when i got a flat because WHO WOULD A' THUNK that it was reverse thread. I know this was an old reply but do you have any idea where I can find them?
Thanks for any reply,
Brian
  #6 (permalink)
Old 03-27-2006, 05:52 AM
jowilker's Avatar
jowilker jowilker is offline
1966 Ford F-100
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
jowilker jowilker
highcountry, Unless you have a high cube low weight use for the trailer, I don't think it would be a good candidate. Think about the big hiway trailers. Look under a box trailer and there isn't much to see, a flatbed has much more frame under it, the lowboys have more. The tt uses the ridged sides and top to keep everything together and has a light weight frame, also it is not a cargo hauler so there isn't much extra factored in. IMHO
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #7 (permalink)
Old 03-27-2006, 06:19 AM
Edkajo Edkajo is offline
Edkajo is gaining momentum as a positive member of FTE.
Can't help with the axles but just adding .
We had a 1977 21' tandem axle travel trailer but it had the standard 15" (dodge van )rims on it (IIRC) with the reverse lug bolts. I'm positive the gvwr on it was 5500lbs. Was thinking of doing the same with a new bed using the old frame and axles. I ended finding a buyer for the old camper and never did it.
Just realized this was from 2002
Tags
axle, axles, bolts, conversion, dayton, dodge, fayette, id, identification, lug, older, parts, rim, rims, split, trailer, travel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
