Spray On Bed Liner, What Color? - Ford Truck Enthusiasts Forums
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners Tonneau cover, caps, racks, canopies, shells, etc.SPONSORED BY:
Click Here
Old 03-23-2009, 05:11 AM
BartStar BartStar is offline
BartStar is starting off with a positive reputation.
I was asked what color of the spray on bed liner I wanted.
I told them "Black" because I have seen red and blue spray on liners fade, and I figured the black will fade into gray.
The dealer told me they can make it the exact same color of the truck and the new spray on liners are warranty not to fade.
I said, "No" I will still take the black liner.
Dealer told me the truck would look better with the blue liner that matches the color of the truck, still said "NO" I will go with black!
I have seen other guys with spray on liners that fade very quickly in the sun, the red fades into pink and they make fun of him of the pink color and calls him a girly man.
What do you guys think?
Does the new technoligy in paint and liners changed for the better?
Is it true that the new liners don't fade?
Old 03-23-2009, 06:27 AM
pkvir's Avatar
pkvir pkvir is offline
pkvir is starting off with a positive reputation.
I'm with you; black.
Old 03-23-2009, 07:05 AM
Chris Anchor's Avatar
Chris Anchor Chris Anchor is offline
Chris Anchor is gaining momentum as a positive member of FTE.Chris Anchor is gaining momentum as a positive member of FTE.
I did Black also, I figured easy touch up if ever needed. Plus I think most of the newer sprays are UV protected. Chris
Old 08-21-2009, 03:19 PM
DCRanger's Avatar
DCRanger DCRanger is offline
DCRanger is starting off with a positive reputation.
Line-X Which Color?
Sorry to hijack an old post but same question here. I have a new 2009 F-150 XLT 4X4 Screw in Sterling Grey Metallic. I've settled on the Line-X but which do you think would look better, Line-X Xtra in Black or the Xtra with Sterling Grey Metallic color match. There's a $175 price difference so I'm leaning towards the black.
Old 08-21-2009, 04:20 PM
tvsjr tvsjr is offline
tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.
Black. You're introducing several more things to go wrong when you color match (does the color match, fading, etc.) and it doesn't look any better, in my opinion.
Also, if you're going to add a cover (bakflip, etc.) the color doesn't really matter.
Old 08-21-2009, 04:30 PM
moab_cj5 moab_cj5 is offline
moab_cj5 is starting off with a positive reputation.
I have an 09 Platinum that is Sterling Gray too. I had a LINE-X liner put in, but my preference wasn't for black. It gets too hot IMO (just my opinion) so I had them make a specail gray blend for me because I didn't want to spend the additional $300 for the color match.
If you go to the LINE-X website, they describe the technology they use to "Guaranty" the color won't fade. They order paint from the factory that is an exact match to your truck, then spray a special UV top coat over it to ensure it won't fade.
The guy that did mine told me that if I don't like the color they did for me, they can spray over it with the Color and protectant to make it exact.
Hope that helps you out. I like the look of mine. It isn't an exact gray match (like I said above), but to me it looks fine, and it isn't black.
Old 08-21-2009, 04:47 PM
DCRanger's Avatar
Thanks. I know the black will look good, not too concerned about heat. And I'm also not convinced the Sterling Grey color will match, even though they say they use the same paint code as the body. I'll have to sleep on it.
Old 08-21-2009, 04:57 PM
Quote:
I will try to upload some pictures of mine. I don't think you can go wrong with black though.
LINE-X is a leader in the industry though. That is a great choice.
Old 08-21-2009, 08:35 PM
Six months later and the black still shines. Chris
Old 08-21-2009, 09:03 PM
ChargersFanInCO ChargersFanInCO is offline
ChargersFanInCO has a good reputation on FTE.ChargersFanInCO has a good reputation on FTE.ChargersFanInCO has a good reputation on FTE.
I finally SAW a colored one today that actually gets used!! It was a Line-X, and it was faded. It was a red, that had turned pink after 2 years. Where it was freshly scratched, it was red. I'm sure the Truckster will argue, but the guy says his colored one scratches a helluva lot easier than the black one on his kids truck. I know I scratched my Line-X with a bicycle pedal once. Dinged it all the way to the paint underneath.
Old 08-21-2009, 10:40 PM
SteveVFX4 SteveVFX4 is offline
SteveVFX4 is starting off with a positive reputation.
Quote:
say what, I thought that stuff was supposed to be strong and durable? and you pay $400 to $500 for it?
I never really seen Line-X in person, but seems everybody swears by them. I don't get the color matched ones, it's going to get all dirty?
I've been perfectly happy with the factory drop in liner, and my mountain bike pedal can't bust through it! Flame away...
DCRanger's Avatar
Black it is
Old 08-22-2009, 03:47 PM
The Line-X was in the truck when I bought it. I didn't buy it. I have Rhino in my 08, and it's just fine. Haven't scratched it yet. I'll never buy a Line-X after getting my Rhino for $200.00 cheaper. I haul rocks, firewood, and all kinds of other stuff and it washes right out and stays shiny.
Yes, the colored ones do fade apparently. They fade faster than the paint does, and that's FOR SURE. "The colored ones are a rip off if you use your truck bed and it sits in the sun". That quote is from a guy in Fort Collins that has a pink Line-X.
Old 08-22-2009, 05:26 PM
smcrae's Avatar
smcrae smcrae is offline
smcrae is starting off with a positive reputation.
I put a black Line-X liner in my Sterling Grey truck.
Matches the bed extender and black plastic tailgate panel better than Grey would have.
Old 08-22-2009, 09:37 PM
DCRanger's Avatar
Had the Black Line-X Xtra installed today by the Dealer in Fredericksburg, VA. I highly recommend him. It looks great and I'm sure it'll be tough as nails. When it stops raining I'll post some pics. Thanks for the inputs
Best Spray in Bedliner? 640 CI Aluminum FORD 2009 - 2014 F150 40 01-13-2017 03:46 AM
Painting over old bed liner Blueoval25 Paint & Bodywork 2 10-22-2016 08:13 PM
Rhino Color match Bed Liner Fading? BossGasser Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners 5 02-18-2014 05:12 PM
LineX Question dbossman Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners 24 10-14-2012 12:50 AM
Premium One Spray on bed liner? gafleeman 1999 to 2016 Super Duty 2 05-30-2011 10:30 PM
Tags
150, bed, code, colors, ford, fusion, grey, liner, liners, metallic, paint, pink, spray, sterling, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
