memphis area, anyone with a good scanner and experience?
I have a SCT tuner that will scan most of your problems. I can let you use it when ever you want. Its vin locked to my old truck but it will still scan most Fords up to 03 models. I use it to scan my car when its check engine light comes on. I can also get the diesel tech from Landers Ford to fix it after hours if it needs repairs. You would have to bring it to Collierville.Let me know if you are interested. I need a day or 2 to get in touch with him. He can borrow the Ford scanner & find any problem you have.
Lariat97, Thanks.
right now it's at the shop getting that oil leak fixed on the turbo. I wished there was a way to test or repair that TSperformance chip. would like to keep it but it makes it run a little rough i think. I will remember you though if i need some other work or need to scan it again i hope it will all be worked out this time.
F-250 restorer
44
04-10-2014 09:52 PM
Howard
06-15-2005 09:53 PM
