48-50 metal shroud? under front of engine
Speaking of fan shrouds, what is the purpose of the metal cover that bolts to the bottom of the frame under the front of engine area? whats it called? and does anyone know if they are the same 48-50 to the 51 52?
I have the one that came off a early 50 but have not checked to see if it will fit my 51 yet. did they help with airflow and or cooling ?
Thanks
Josh
Thanks
Josh
Are you talking about this???
I also have these in my collection.
Note how the first one pictured and the one on the left in the second picture are the same, but the one on the left in the second picture has a hole cut out. Also, note how different the one on the right is.
The one up top came out of a 49 Panel with an unknown engine. The others, I believe, were purchased on eBay and should be for a 51 and 52 respectively. However, I may be mistaken. I'm sure that a every engine required its own shield design.
Quite frankly, I forgot that I even had these parts.
While on the subject of obscure parts, I also came upon a set of these...
48-51 fender gravel shields
And a set for 52. Note the different hole positions and bottom curvature of the shield on the left.
I know the black one pictured in the lower right of the photo is indeed a 52 with a V-8 as it is identical to the one I have on my 52 F-1 which is basically un-restored. It's called either a splash or gravel shield but not really sure what purpose it really serves as most were probably discarded years ago just like the engine splash shields on the Models T's and A's.
on
Thanks
Josh
Thanks
Josh
I've found that this piece is appearently not only good as a gravel sheild but as a location for all of the oil, greese, coolant and 60 some odd years of dirt to collect.
Mossy, on the passenger side of the truck this piece is easily identifyable by looking for a large shelf under the front engine mount. It will extend from the radiator shrowd to about 4 inches behind the engine mounts. there was so much dirt and **** on mine that I actually had to DIG the engine mount out of it to check the mount. I located this "shield" piece two 5 gallon shop vac loads later and still haven't gotten it all cleaned off.
