1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Manual Steering Box rebuild for 1961 unibody.
Old 03-22-2009, 08:59 PM
donmodro's Avatar
donmodro
donmodro is offline
Does anyone know where I can source the parts to replace the bearings/bushings in the steering box on a 1961 unibody f100 with the manual steering box?
I keep finding bits for the 1960 and earlier trucks, and the 64 and later ones, but not the one I am looking for.
Any ideas?
Old 03-23-2009, 08:43 AM
unibody62's Avatar
unibody62
unibody62 is offline
I had trouble with my '62. I ended up just going to a local bearing shop with my parts, they fixed me up with some bushings and seals. As I recall, I didn't even have all of the parts, because the seal had been removed and the gear filled with bearing grease. I think I told them what I model I was working with and they had the spec sheet for it. The place here in Akron, Ohio is called Bearing Inc. I think it may be a national company.
Old 03-23-2009, 10:07 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
I keep finding bits for the 1960 and earlier trucks, and the 64 and later ones, but not the one I am looking for.Any ideas?
Welcome to FTE
Where are you getting this what fits what jazz?
I know it's not from any Ford parts catalog.
The following parts are the same 1961/65.
1966/72, the sector shaft bushing is different, everything else is the same.
Except for the sector bushing, these same parts also fit 1960/72 passenger cars with manual steering.
2) C2AZ3571A .. Steering Shaft Bearing
2) C2AZ3552A .. Steering Shaft Race
1) B8A3576A .. Sector Shaft Bushing
1) C3AZ3581A .. Housing Gasket
1) C7OZ3591A .. Housing Seal
All these parts are obsolete.
GREEN SALES CO. in Cincinnati OH has everything: 800-543-4959.
PARTS INTERNATIONAL in Farmers Branch TX has everything but the sector bushing: 888-727-0418.
KINSEL L/M in Beaumont TX has everything but the sector bushing: 800-816-2894.
Kinsel will be cheaper than Green Sales, dunno about Parts Int'l.
I also found several of the sector shaft bushings (only) at other obsolete parts vendors & Ford Dealers.
Old 03-23-2009, 04:50 PM
donmodro's Avatar
donmodro
donmodro is offline
Awesome. Thanks.
chris starscream
03-07-2017 06:47 AM
scf100
11-22-2016 04:08 PM
chris starscream
10-21-2015 03:56 PM
unibodynewbie
11-09-2009 09:04 PM
donmodro
05-08-2009 11:53 AM
Quick Reply: Manual Steering Box rebuild for 1961 unibody.
