Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 03-22-2009, 10:29 AM
2001LSV65SPD's Avatar
2001LSV65SPD 2001LSV65SPD is offline
2001LSV65SPD is starting off with a positive reputation.
Exclamation Help with Tach install.
I did a search and found in a post to hook the signal wire for the tach to the yellow / tan wire coming from the coil. I did this and nothing. I also did a search for a wiring diagram for behind the radio and couldnt find one. The PO installed a stereo and did not use an adapter he cut all the wires. Any help???
Thanks.
I can post picks if needed.
__________________
1995 F250HD 4WD 351 5spd 3" Body Lift 33" Tires, 10.25 Sterling 4.10, Std Cab Long Box
2005 Lincoln Navigator 4wd Ultimate pkg
2001 Lincoln LS V6 5spd
  #2 (permalink)
Old 03-22-2009, 11:13 AM
Nitramjr's Avatar
Nitramjr Nitramjr is offline
Exiled from the club.
Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold
Do you have the rest of the tach wired correctly? You will need a power source and a ground in addition to the tach signal for it to work. You can (but don't have to) have the fourth wire hooked to a power source for the back light. I usually just twist the wire for the light and the 12v power for the tach together and leave the light on all the time.
Also make sure you are using the correct wire from the tach to the tach signal.
I'll go outside in a bit and see what color the wire is on my truck that I have the tachometer hooked to.
__________________
Ray
'97 F250 XL, 5.8L, '05 Escape Hybrid, '06 Escape Hybrid
  #3 (permalink)
Old 03-22-2009, 11:25 AM
lew52's Avatar
lew52 lew52 is offline
lew52 is gaining momentum as a positive member of FTE.
The signal wire goes to the neg side of coil...
  #4 (permalink)
Old 03-22-2009, 11:43 AM
lew52 The signal wire goes to the neg side of coil...
I understand, what color is the neg.? The post I found said it was the yellow / tan.
I am confirming the rest of the wiring now but it sucks with out a diagram. I tied the power and ground into the radio power (ACC) and the ground in. I will change the ground and test it again. Do you need the light to test I have not found A spot to tie that in and tested without it.
Thanks for the input.
__________________
  #5 (permalink)
Old 03-22-2009, 11:53 AM
lew52's Avatar
I have a 95 302 so the color is not the same..With a test light with key on check witch wire has power..That will be poss so the other is neg
  #6 (permalink)
Old 03-22-2009, 12:34 PM
__________________
  #7 (permalink)
Old 03-22-2009, 12:41 PM
Quote:
With the key on both have 12vdc??? Is this possible. I checked it grounded at Battery.
__________________
  #8 (permalink)
Old 03-22-2009, 12:57 PM
Nitramjr's Avatar
I just looked at my truck and the wire you are connected to in the photo is the same one I have my tach hooked to. I'd start looking at the rest of the wiring. I wouldn't use the radio ground - go to a good ground somewhere under the dash. Also, for power, make sure you get switched power, not something that is always hot.
The tach wire that is for the light can be twisted together with the power wire as long as you don't want to dim the light with the dash lights. I wired the one in my truck right to the dimmer for the dash lights. Works nicely and wasn't too bad to do.
__________________
Ray
  #9 (permalink)
Old 03-22-2009, 01:03 PM
Thanks alot guys.
I just double checked all the connections and its working. Thanks for the help I will post picks when its finished.
__________________
  #10 (permalink)
Old 03-22-2009, 01:42 PM
Nitramjr's Avatar
Quote:
Glad you got it up and running. I like where you put your. I was going to use that location except the P.O. used it to install some switches for lights that aren't on the truck any more.....I mounted mine to the side of the steering column.
__________________
Ray
  #11 (permalink)
Old 03-22-2009, 02:54 PM
Nitramjr thanks for the help. Here it is all buttoned up.
I really need a new instrument cover but there are other things I want worse. Glued it all up and its one piece again. I would have felt bad if I cut up a pristine piece but I had nothing to lose. The tach was free, I would have purchased one that mounted a little different.
__________________
  #12 (permalink)
Old 03-22-2009, 09:00 PM
Nitramjr's Avatar
That's a nice looking install on the tach......you just need to move the shift indicator up by another 1000 rpm or so....
__________________
Ray
  #13 (permalink)
Old 07-04-2009, 03:48 AM
isenegger's Avatar
isenegger isenegger is offline
isenegger is starting off with a positive reputation.
thats is tacky....i would have done something cleaner with the install
__________________
2002 Ford F150 Sport 4.2 5spd,
1988 Ford F150 4x4 4.9 4spd, 39.5" boggers
  #14 (permalink)
Old 07-04-2009, 07:36 AM
Nitramjr's Avatar
Quote:
What is tacky about it? I think it is a great place for the tach. Nothing obstructed, it is in the line of site and no wires showing. I like it better than where I put mine (on the column),
Let's see a picture of your aftermarket tach install for comparison.
__________________
Ray
  #15 (permalink)
Old 07-04-2009, 10:34 AM
isenegger's Avatar
i have swapped clusters to a factory tach. i would have fiberglassed it a little to make it cleaner.
__________________
Tags
2005 , 87 , 95 , 97 , coil , f150 , ford , guide , install , installation , lincoln , navigator , stereo , tach , wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
