Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 03-22-2009, 07:26 AM
ron570 ron570 is offline
Garage is empty, add now
ron570 is starting off with a positive reputation.
HD tow pkg, or not
May buy a new 2008 left over expedition King Ranch, but it doesn't have the HD tow pkg. While I don't tow, I drive 100 miles per day highway with steep inclines. Is this a concern with heating the transmission and engine, or am I better off finding one with a HD tow pkg which includes bigger radiator & trans oil cooler.
  #2 (permalink)
Old 03-22-2009, 08:05 AM
thinksnow thinksnow is offline
thinksnow is starting off with a positive reputation.
If you like the truck that much just buy it. You can install a aftermarket trans cooler thats better then the factory system and they aren't too expensive.
  #3 (permalink)
Old 03-22-2009, 08:07 AM
Quote:
True, but what about the bigger radiator, alternator & battery? Also is the rear differential different in towing pkg?
  #4 (permalink)
Old 03-22-2009, 08:30 AM
Well from reading your original post if you don't tow you don't have to worry about any of that. Even with steep inclines the stock set up should handle it just fine. I would still do the aftermarket trans cooler though. A cool trans is a happy trans.
  #5 (permalink)
Old 03-22-2009, 10:02 AM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
The only items in HD Tow I'm aware of are the slightly larger engine coolant radiator, the larger transmission cooler, and the seven pin wiring to the rear of the truck.
To my knowledge the alternator and battery are the same in all Expeditions.
HD Tow still has the 3.23 (?) axles in '08 and later. My '07 got the 3.73 as part of HD Tow, but I think that's now a separate option.
Transmission heat is a killer but most heat comes from the slippage during shifting. The Expeditions seem to lock up pretty quickly, even when towing.
If you're concerned get the Interceptor OBD2 gage, set it for transmission and coolant temperature, and put it on your dashboard. I doubt you'll note excessive temperatures but the gage will let you know what's happening. Just plugs into the OBD2 connector under the dash. Mine is just velcroed on top of the dash in a cheap pod.
Click the image to open in full size.
-- Chuck
Tags
hd, pkg, towing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
