02 f250 4x4 7.3l trouble.HELP
When i start truck in morning, it chugs then dies. i give it gas then let up and it dies. then after the third time i let it sit for awhile and it's ok. this has been going on for months. But this morning after the fourth try the truck died and now wont turn over. Help
Like F350-6 says you really should scroll down the main Forum page to the diesel section and post your problem on the powerstroke page.
However when you say it will now not turn over do you mean that the starter motor will not turn the engine over? If so you may need to charge the battery or check the battery terminals.
The starting problems could be bad glowplugs or bad glowplug relay and possibly a fuel delivery problem (clogged fuel filter or bad lift pump or loose pipe connection). The powerstrokes are electronically controlled so very specialized and so I am just guessing, the guys on the powerstroke page will know a lot more.
Good luck.
Good luck.
