Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 van SPONSORED BY:
  #16 (permalink)
Old 03-22-2009, 06:52 PM
texan2004's Avatar
texan2004 texan2004 is offline
Garage is empty, add now
texan2004 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by msgtg View Post
LOL...to fix the problem...plug it in overnight, or for a couple of hours before you start the truck.
Mine is an 03 with 85K on it now. I plug her in anytime the temps drop below 40 degrees. Stop and apply logic to this. When the temps drop that oil will get thicker (I use the Rotella 15w40) which puts a strain on your entire starting system as well as the motor parts. Around here it's not unusual to get down to 5 to 10 degrees. When I plug the truck in, it starts just like it was 80 degrees outside...fast start, no smoke, no knock/rough idle.
There have been times that I've had to leave the truck for a couple of days at the airport. When I've come back, of course the truck hasn't been plugged in and it takes much longer for the glow plug light to go out and when the truck starts....smoke, knock, rough idle....heck she sounds downright terrible! If anyone is around when I've had to start it like that I just know they think that I've blown it up.
BUT, as was mentioned above, once it runs for 3 or 4 minutes, she smooths right out. And yes, it only happens when it's been cold soaked. If you run it and start it 3 or 4 hours later, she'll start right up.
Save yourself an ulcer...plug the truck in. It'll also make your starter and batteries last a lot longer!
Joe
Let's for the moment say you are correct. Then why was it that I never had to plug in the truck for the first five years that I owned the truck?? I remember being in Cheyenne, Wyoming one November morning n 2004 and the tempp was -6*F when I went to start the truck after it had been sitting outside overnight. I did let the glow plugs heat up when I went to start it but I did not have the truck lugged in over night. It started right away. Today, I have the problem described in the first post up to about 65*F. Finding a way to address a symptom does not fix the problem. I want to know what the problem is so that I can fix it without throwing moeny away on un-needed new parts.
__________________
2012 F-250 King Ranch
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6 + 1950 F6
  #17 (permalink)
Old 03-22-2009, 07:09 PM
rnolloth rnolloth is offline
rnolloth is starting off with a positive reputation.
Quote:
Thats the same way my truck was.But when it got bad my truck woukd ru bad when it was 70 outside.Unfortunately youll be replacing injectors as well.Let me know if you have any questions Ryan.
  #18 (permalink)
Old 03-22-2009, 07:12 PM
msgtg's Avatar
msgtg msgtg is offline
1992 Ford F-150
My Garage
msgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to behold
Sorry Pal, I obvously don't have the answer to your question.
Joe
__________________
03 F250 King Ranch Crew 6.0 4x4 92 F150 XLT SuperCab 4x2 03 Intruder Volusia 03 Ranger XLT
WV Chapter Lead JOIN THE WEST VIRGINIA CHAPTER CLICK HERE
We live in the Land Of The Free...BECAUSE of the Brave! My humble thanks to all Veterans, past and present
  #19 (permalink)
Old 03-23-2009, 05:48 AM
sethjamto's Avatar
sethjamto sethjamto is offline
2003 Ford F-350
sethjamto is starting off with a positive reputation.
Okay....so it sounds as though I may have an injector going out on me. First off, how do I know which ones are good or bad and how many I need?
Secondly, is this an easy swap out for me in the driveway or do I need to bring it in? Can someone walk me through changing out an injector?
Thanks for the link to the Pensacola diesel for the cheap injectors!
__________________
2003 F-350 6.0 SC Longbed 4x4 6 speed manual SRW
Cat Delete Pipe
Airaid air filter
2004 Dodge Durango 4x4
2008 Harley Road Glide FLTR
2001 Honda Rubicon 500 4x4 Hondamatic
  #20 (permalink)
Old 03-23-2009, 06:25 AM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Some decent info in this link......
6.0L Powerstroke Injectors
__________________
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower250A;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD BilletWaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
  #21 (permalink)
Old 03-23-2009, 08:26 AM
texan2004's Avatar
Thanks for the link Mark, very helpful. This is what I was looking for. Looks to be a moderate P.I.T.A. to confirm the diagnosis but it is what it is I suppose. Thank you again.
__________________
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6 + 1950 F6
  #22 (permalink)
Old 03-23-2009, 09:49 AM
Thumbs up
They were not as hard to do as i thought they were going to be.But im also a mechanic so it should be easier for me.If you have any question PM me and ill help you out.
  #23 (permalink)
Old 03-23-2009, 10:07 AM
texan2004's Avatar
Appreciate it Mark. May be a week or two before I can block out the time to do it.
__________________
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6 + 1950 F6
  #24 (permalink)
Old 03-23-2009, 12:38 PM
sethjamto's Avatar
2003 Ford F-350
Well, this morning it was about 25 degrees out. I cycled the ignition 3 times, waiting for the glow plug indicator to go out each time. After the 3rd time, I started the truck and she was smooth as silk with no rough idling or smoking.....does this mean that the injector(s) could be good and a possible bad glow plug?
...who knows.....
__________________
Cat Delete Pipe
Airaid air filter
  #25 (permalink)
Old 03-23-2009, 12:43 PM
Jack B Duff Jack B Duff is offline
Jack B Duff is starting off with a positive reputation.
F350 Hard Start
I to am having hard starts with my 04 F350. Took it to my dealer and was told it needed a FICM, $1400. Took it back to my shop and switched the FICM out of one of my 06's. Did not make any difference and the FICM from the o4 works fine in the 06. So it would appear not to be the problem. There was a string on this forum a couple years back that addressed this same problem. If you Google TSB 08-26-3, you will come up with a service bulletin from Ford that may help. This can be installed for free if you are still under warranty otherwise it will cost. I have to now go back to my dealer and argue that my FICM is not the problem. If you have any ideas let me know. Also, if you get this upgrade done, let us know the outcome
Also, I have 5 of these trucks. The 05, the 2 o6s and the 07, all start and drive without being plugged in at -20. The 04 F350 and 04 Chev with Cat engine need to be plugged in. Wouldn't it figure, the trucks under warranty start.
Jack
  #26 (permalink)
Old 03-23-2009, 12:52 PM
There is a newer pcm flash from the dealer but it didnnt help mine.It did hurt the fuel mileage though.Sounds like injectors to me.
  #27 (permalink)
Old 03-23-2009, 06:06 PM
texan2004's Avatar
Jack
This is good to know. You are very fortunate in that you have the ability to "parts change" for only the cost of your time. I am suspecting that what we all have is an injector or two that hangs up over the course of an extended downtime (overnight) but manages to get freed up after the trucks runs for a couple of minutes. The only folks here that seem to get the problem fixed are the ones that do injector change outs. I just wish that there was an quick and easy check for this and lit appears as though this is not the case.
__________________
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6 + 1950 F6
  #28 (permalink)
Old 03-23-2009, 06:19 PM
Hey guys if you can get someone to scan your truck (other than someone like Auto Zone) someone that can get the factory codes.If you can get them it will tell you which cylinders have a blance/ injector problem.Hope this helps.
  #29 (permalink)
Old 03-23-2009, 10:01 PM
FlyCanadianGuy FlyCanadianGuy is offline
FlyCanadianGuy is starting off with a positive reputation.
I solved this problem. Just like Jack B mentioned it was $1426 for a new FICM (it hurts because im only 6000km out of warranty and the service rep even mentioned he sees ALOT of these come in and personally thinks they need to be recalled) and I will let you know tommorow morning if she wont start in the morning(no way am I plugging it in, I have started it at -30 celsius before without plugging in)
__________________
'05 F-350 6.0L CC Lariat
6" Rancho Lift
ARP studs
Full EGR delete
MBRP Turbo Back
Learning from the best. You Guys!
  #30 (permalink)
Old 03-24-2009, 06:16 AM
RogerKeyte RogerKeyte is offline
RogerKeyte is starting off with a positive reputation.
I think the plug in is a red herring. I had those problems at 60 and 70 f
Tags
2003, 60, f250, ford, injector, powerstroke, rough, smokes, start, starting, starts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
