Still misfiring on same cylinder P0304
Guys the girl friend just got an '02 Escape with 3.0L V6 and 162k on the clock. The dealer she got it from said they replaced cylinder #4 COP. So the day she bought it the CEL came on, I ran the codes with my cheaper MAC tools scanner and I got code P0304 for cylinder #4 misfire detected. So I tore the cover off and verified that yes the dealer did replace #4 COP. So then what I did was I switched the #4 COP with the #5 COP and replaced #4-6 spark plugs all at the same time. Then I reset the light but after a few drive cycles the CEL will come back on and give me the same P0304 code thinking #4 is still misfiring. Her Escape runs like a champ, has plenty of power, idles smooth, doesn't sound like its missing. The only thing I do not know is if its using gas excessively because I do not drive the thing on a regular basis. What am I to do to get the CEL to go away? I do not understand what could be causing the computer to think #4 is still misfiring. Should I just yank the battery for a little while and let it reprogram itself?
Thanks for the help guys!
Shane
Glynn Motorsports
Shane
Glynn Motorsports
Shane
Glynn Motorsports
If you had a scanner that grabs the Freeze Frame Data would tell you how fast you were going and at what RPM when the DTC was set. My scanner will monitor 20 PIDs continuously at a user set interval and then when you press a button it will capture so many interval then stop. You can wait for a event like a CEL, hit the button and you have a before/after capture showing exactly when you hit the button.
payntertk31
Escape & Escape Hybrid
16
05-11-2020 09:12 PM
RetroActv
1997-2006 Expedition & Navigator
07-12-2012 01:30 PM
