Towing Jeep behind 5th wheel - Ford Truck Enthusiasts Forums
Old 11-21-2002, 07:31 PM
Jeepincj7's Avatar
Jeepincj7 Jeepincj7 is offline
Jeepincj7 is gaining momentum as a positive member of FTE.Jeepincj7 is gaining momentum as a positive member of FTE.
Looking for info on doing this in CA. I have been told by a couple of RV stores that towing behind a 5th wheel is legal with a noncommercial Class C license as long as the total length of the setup doesn't exceed 56ft. Anything over 56' would require a CDL which is way too much hassle.
Has anyone in California done this? I have been looking at numerous 5er toy haulers that could carry the Jeep (4500lbs), and am not finding anthing in my price range. So, I have found a very nice 24' 5er that meets my needs, and I should still be under the 56' rule.
Thanks,
Scotty
Old 11-21-2002, 08:55 PM
theonlybull theonlybull is offline
theonlybull is starting off with a positive reputation.
are you gonna put the jeep on the 5th wheel trailer. or tow behind a 5th wheel travel trailer??
Old 11-22-2002, 01:35 AM
Jeepincj7's Avatar
Flat towing behind the 5th wheel.
Old 11-29-2002, 01:35 PM
genspot genspot is offline
genspot is starting off with a positive reputation.
Old 12-01-2002, 01:38 PM
PSD_Power's Avatar
PSD_Power PSD_Power is offline
PSD_Power is starting off with a positive reputation.
Could you take the cdl test with your truck? I have wondered if I could do that set up. If I could take the test in my truck I might do it. My truck is 50.5' long with trailer. I just don't want to have to find someone with a semi to take my test in.
Justin
http://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=9313&.jpg
http://66.179.41.42/gen1/build/realgeneral.jpg
2002 F-350 SC LB 4X4 6SPD PSD. 3.73 gears. 2.5" leviling kit. K&N air filter. Rhino lined Bed. Prodigy trailer brake controler. 35x12.5x16.5 BFG A/T. 16.5x10 ultra wheels. pop up gooseneck hitch and firestone airbag spring helpers. Reese fifth wheel hitch for my new toy hauler. Superchips microtuner.
Old 12-03-2002, 12:31 PM
Scotte Scotte is offline
Scotte is starting off with a positive reputation.
[updated:LAST EDITED ON 03-Dec-02 AT 12:38 PM (EST)]>Looking for info on doing this in CA. I have been told by a
>Thanks,
>Scotty
Take a look at the CA. DMV website.
WWW.dmv.ca.gov/dl/dl.htm
or contact: 1-800-777-0133
The Commercial Driver Handbook should explain the CDL exceptions.
You do not need or want a CDL unless you are a professional driver/for compensation. All traffic violations whether in your personal car or commercial vehicle go onto your CDL. It is much easier to have your CDL suspended or revoked than a regular drivers license. In California, the book states "only professional drivers will receive and keep a CDL." You may need what is called a "NON-COMMERCIAL Class A" drivers license for over 56 feet. Give the DMV a call at the number above for more information. Good luck.
Old 12-05-2002, 05:03 PM
dpoelstra dpoelstra is offline
dpoelstra is starting off with a positive reputation.
You won't need a "commercial" driver's license, but a Class A. Yes you can take the Class A test in your truck. Many 15 passenger van families have to do this.
Old 12-05-2002, 05:39 PM
Jeepincj7's Avatar
A CDL is required with a Doubles and Triples endorsment. So, the 56' rule is just a myth. I spoke with the Commercial Driver's Division of the DMV in Sacramento this week.
Three tests are required. Two written tests, and a driving test using the 5th wheel. You must also meet the medical exam requirements to be approved for the license as well as a $57 application fee.
A non-commercial Class A is not acceptable to do this.
Scotty
Old 12-06-2002, 06:51 AM
>Scotty
If you go this route understand that there are a lot of different rules and regulations that go along with a CDL.
You are considered legally intoxicated at 0.04 BAC with a CDL, not 0.08 BAC that a regular drivers license holder gets away with.
Two serious traffic violations within 3 years, you will loose your CDL for at least 60 days.
Three serious traffic violations within 3 years, you will loose your CDL for at 120 days.
Note: In October of 2002 new and more strict rules went into effect. Your personal vehicle traffic violations are now counted on your CDL, you do not have to be in a commercial motor vehicle any longer.
As far as the DOT medical goes, it is only good for 2 years if you are in good health and can be cut down to 3 and 6 month certificates if you have medical problems:
if you are a diabetic requiring insulin, you will not pass.
if you have high blood presure, 181/105, you will not pass.
The list goes on and on.
I just want you to understand that it is much, much more complex than you might imagine. Many of the guys/gals that have left the profession gave up their CDLs. They no longer wanted the hassels that go along with them. Good luck and Happy trails.
Reese Goose Box Sarge261 Fifth Wheel & Gooseneck RV Towing 94 02-09-2016 01:29 PM
Gear Ratio DocFallick03 1999 to 2016 Super Duty 8 05-26-2015 01:21 PM
5th wheel registration question redz284u S. California Chapter 15 04-04-2015 10:04 PM
Calcing Max Towing Capacity Tyrellm 1999 to 2016 Super Duty 8 10-20-2014 11:11 AM
Tranny Studdering, Shaking Almost.. WTF? Fusion7.3 1999 to 2016 Super Duty 4 05-29-2014 03:28 PM
Tags
5th, jeep, tow, towing, trailer, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
