Replacing a power steering pump for $464?? - Ford Truck Enthusiasts Forums
Old 03-20-2009, 03:08 PM
Bertha1 Bertha1 is offline
Bertha1 is starting off with a positive reputation.
Angry Replacing a power steering pump for $464??
Someone please help me out here. I just took my truck to midas (because it's next to my office) and they said the serpentine belt has been shredding because of the power steering shaft is moving in and out on the pump. He showed it to me and claims that is why the belt is working off the pulleys which seems to make sense.
He gave me a quote of $127 for parts (advance has it for $44 with the reservoir) and $282 for labor. Is replacing a power steering pump really this hard? I'm a little nervous to do it myself because of this labor charge, it must be complicated or hard to do right? I'm reading online and it doesn't look that difficult plus I have a chilton at home but am worried I'm missing something.
Is this really a job for the shop or can your average person do this?
Old 03-20-2009, 03:27 PM
truckertom21 truckertom21 is offline
truckertom21 is starting off with a positive reputation.
find out how many hours they say it will take...i dunno if you will need to blead the ps lines after replaceing the pump i think you will but i've never had to do one though...also i'm going to assume that your a female? sorry if im wrong but mechanics will prey on females and tell them that its going to cost way more then it should, also the part price diffrence is because of the mark up i'd say this place is trying to rook you but then agane i hate takeing my stuff to the mechanics...i say they all rook people
Old 03-20-2009, 03:35 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is online now
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
How much play is in the shaft? The two pumps I have both have maybe 1/16" of play in and out, maybe slightly more. Can you see it move in and out while the engine is running with the belt on?
Old 03-20-2009, 03:41 PM
fmr9 fmr9 is offline
fmr9 is gaining momentum as a positive member of FTE.
Midas is getting in your pocket real good.
It is not a hard job. You do not need to bleed anything, it will bleed its self.
You will need to borrow a power steering pump puller to remove and instal the pulley. Advance, or Auto Zone should have these in their tool loaner program.
Just take care that when you are done, the pulley is in line with the other pulleys in the system, or it will shred the belt.
Take your time, and work careful. This one is not rocket science.
You could take the oportunity to upgrade to a better pump, that will not howl all the time, and will decrease the effort needed to turn the wheel. The cost of the pump is a little more than the stock one. There are a couple of different ways to do this. Do a seach to find the info.
Good Luck Frank
Old 03-20-2009, 03:48 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Good Luck Frank
Couldn`t agree more. Your manual will guide you. But pay attention to what EPNC says first.
Old 03-20-2009, 03:50 PM
1994 F250: 351, C6 1994 F250: 351, C6 is offline
1994 F250: 351, C6 is gaining momentum as a positive member of FTE.
Replacing a power steering pump is not a difficult job at all. With the prices auto repair places charge you would think every job is difficult, but they have to make money. As long as they are honest and charge a competitive rate you cannot knock them for charging enough to make money. The only way to still own a vehicle and avoid their high charges is to invest in some good tools, a manual, and do the work yourself.
Old 03-20-2009, 03:53 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Is the P/S pump really the problem, or could it be something else?
Before spending the green for a replacement P/S pump, take a look at the belt tensioner.
The bearing in this little darlin' is notorious for failing. That causes the belt to fray, because the tensioners shaft moves in/out, while its pulley is doing the hula.
Wiggle the pulley by hand back/forth in/out (with the engine off...of course )...there should be zero play.
If the pulley wobbles around...it's time for a new tensioner.
EDIT: Replacing the P/S pump:
The P/S pump pulley must be pressed off and on. It doesn't just come off by hand.
This means if you do not have a P/S pump pulley removal tool, you have to take the old pump with you when you replace it, so its pulley can be installed on the new pump.
Hopefully, the autoparts store you are buying the pump from has a machine shop to accomplish this.
Old 03-20-2009, 04:10 PM
I agree that the belt tensioner is the most likely cause of the problem, but I had a PS pump in my Explorer that went to hell and caused the same problem.
Old 03-20-2009, 05:10 PM
Thanks everyone for contributing. Here's what's been done so far, maybe it will help clarify what's still left to do that may fix it.
New within the last week:
air pump
tensioner
p/s sulley
It's weird becasue the belt shreds like 1 rib off then seems to stop. It's frayed and looks pretty tattered. The belt appears to run more towards the radiator side on the crank and radiator fan but on the alternator, ps pump, tensioner the belt seems to be running more on the engine side of the pulleys. If there is play in the ps shaft, could that cause the belt to run off center? I may post some pics since it's tough to explain.
Old 03-20-2009, 05:29 PM
vinced1966 vinced1966 is offline
vinced1966 is starting off with a positive reputation.
Midas is wrong
The play in the PS shaft will not drive the belt off.
Find what is not in allignment with the engine off and a stright edge.
There is play in all ps pumps.
The only thing that will drive a belt off is a pulley with no play that is not in allignment with the other pulleys
Make sure that the PS pulley was driven all of the way on so the shaft in the middle is flush with the front of the pulley.
Make sure the air pump is installed correctle
Old 03-20-2009, 06:55 PM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
Posting Legend
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
on 1 of my trucks, the mounts to the engine was loose. I tightened everything, and put on the better grade of belt, and have had no more trouble. some play in the pump is normal, I wouldn't replace it unless it was leaking oil really bad.
Old 03-20-2009, 10:20 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
All the pulleys should line up when you look down across them from the side of the vehicle, if one of them is skewed find out why, maybe one of the accessory brackets is incorrectly mounted.
Old 03-22-2009, 12:23 PM
McLeod McLeod is offline
McLeod is gaining momentum as a positive member of FTE.
Even if you hire it out, find another shop to do it.
My experience is that Midas charges up to twice what many others will for the job.
5.4L - replacing power steering pump/return line/pressure line - who's done this? nddragon01 2004 - 2008 F150 6 01-01-2017 02:56 PM
Waterpump gasket leak repaired (DIY vs Dealer) wrenched 1987 - 1996 F150 & Larger F-Series Trucks 5 04-14-2015 05:16 PM
McLaughlin Ford Sumter SC Worst Dealership EVER!!!!!! mclarengts 1999 - 2003 7.3L Power Stroke Diesel 19 04-04-2013 09:08 AM
Power steering pump F350_Todd 1999 - 2003 7.3L Power Stroke Diesel 10 03-25-2011 04:16 PM
Request your advice, should I keep my truck? Tahnka Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 32 10-07-2010 04:58 AM
Tags
2003, 79, air, apower, belt, bleed, cost, edge, f250, ford, labor, power, pump, replace, shredding, steering, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
