Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Is this info correct 365 hp for 1997 Lightning engine?
Old 06-27-2002, 04:24 AM
vatainc's Avatar
vatainc
vatainc is offline
I've been told that an engine I'm looking at is from a 1997 Lightning Truck and that it is rated at 365hp. I'm unable to find data that confirms this. Is this info accurate?
Thanks for any assistance you can offer!
Tom Call, Portland, OR
Old 06-27-2002, 11:32 AM
ecarter50's Avatar
ecarter50
ecarter50 is offline
There was no 97 Lightning only 93-95 and 99-later.
Old 06-27-2002, 06:14 PM
vatainc's Avatar
vatainc
vatainc is offline
Thank you for the reply. You have enlightened me as to why I could not find info on a '97 Lightning. An additional question regarding the Lightning engine: Does the block for the '93-'95 Lightning have the same motor mounts as the 5.0L 302? I ask this question as I have a '99 Laforza SUV with a Ford 5.0L 302 (Bronco) set up with speed/density that needs rebuilding/replacement. The engine has 14,000 miles and needs to be rebuilt as it has a compression reading on 35 in #8 cyl.The car weights 5,200 lbs and could used more low end torque. One suggestion I have received is to put a Linghtning engine in. The car has the Ford AOD transmission. Can anyone offer any suggestions on this?
Thank you.
Tom Call
Portland, OR
Old 06-28-2002, 10:23 AM
ecarter50's Avatar
ecarter50
Is the engine you are looking at ebay item #1839836741. 93-95 Lightnings had 240hp not 365 also redlines at 5000rpm not 6000 as the seller lists. Yes a 351w uses the same mounts/bellhousing bolt pattern as 302. Some of the accessory brackets are different.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1839836741
Old 06-28-2002, 11:28 AM
vatainc's Avatar
vatainc
vatainc is offline
Yes, the motor on ebay was the one I was looking at. Can you tell me what the torque rating was on the '95 Lightning engine as for my application torque is more important that HP, but I do understand there is a relationship between the two?
Tom Call
Old 06-28-2002, 03:44 PM
adelyser's Avatar
adelyser
adelyser is offline
It only redlines at 5K? I did not know that. My Bronco with the 351W redlines at 6K, and I just figured that the Lightning was similar in that respect.
Old 06-28-2002, 11:47 PM
sauerf100s's Avatar
sauerf100s
sauerf100s is offline
I had a 93 Lightning. The specs I was told by the dealer was 275 horse, but I can't remember the torque. Wasn't it the non-Lightning that put out only 240 HP?
Old 06-29-2002, 12:45 AM
Spdalit's Avatar
Spdalit
Spdalit is offline
The Lightning put out 240 horse and 350 lb ft of
torque from '93 to '95
Old 06-29-2002, 01:04 AM
Spdalit's Avatar
Spdalit
Spdalit is offline
Surfdaddy
Modular V10 (6.8l)
20
11-30-2016 10:42 AM
SLOPhil
1999 to 2016 Super Duty
08-24-2014 09:48 PM
Joe Fairbanks
New Member Introductions
05-21-2014 10:05 AM
bigtexan99
108
11-02-2007 06:46 PM
oldschool63
04-17-2005 01:07 AM
Quick Reply: Is this info correct 365 hp for 1997 Lightning engine?
