5.0L Coyote 5.0l Ford OHC Coyote engine for 2011+
5.0L production start
Old 02-18-2009, 05:02 PM
f460's Avatar
f460
f460 is offline
The line will run full production for the 5.0 (coyote) after Thanksgiving break 2009.
The volumes suggest Mustang and F-150. A very busy time at Essex plant from now until then.
Old 02-18-2009, 06:12 PM
Power Kid's Avatar
Power Kid
Power Kid is offline
Hmmm so mid-year 2010. Much same as diesel?
Old 02-18-2009, 07:30 PM
f460's Avatar
f460
f460 is offline
I am not sure about the diesel. It looks like the availability of the 5.0 early 2010. The 4.4diesel line is up, from what I have heard. But I do not know when the production start date is. Essex is to be up in late June 2009 for the 5.0. The crank department is running now suppling Romeo plant for the 6.2l engines. Romeo is building 6.2l but I do not know what they are going into. The Harley Davidson F150 had one at the Chicago show.
Old 02-18-2009, 07:38 PM
cpdorroh's Avatar
cpdorroh
cpdorroh is offline
5.0 is released in 2010. Hopefully by 2013 they will have all the bugs worked out, and by then I may be about ready to trade my trusty '09 5.4....... good timing.
Old 02-18-2009, 07:40 PM
Svets96's Avatar
Svets96
Svets96 is offline
Wow their finally gettin serious about the 5.0l. This is all good news. I am gonna be headed up to the Cleveland auto show at the end of this month, maybe there will be one in a concept car, or production truck. I cant wait.
Old 02-18-2009, 09:58 PM
Power Kid's Avatar
Power Kid
So if its not a diesel, and the 6.2L is not available (B'stards!) What will it be: 5.0L V8 or 3.5L ER V6? And why?
I need to know numbers b4 I know. Altough I read the EB is the "premium" of the two.
Old 02-18-2009, 10:36 PM
pkvir's Avatar
pkvir
pkvir is offline
Will the 5.0 take the place of the 5.4, 4.6, or both? What are the hp/torque projections?
Old 02-18-2009, 10:49 PM
Svets96's Avatar
Svets96
Svets96 is offline
Damn there are still alot of unanswered questions with all of the stats. What are we all gonna do? I guess just wait it out.
Old 02-18-2009, 11:08 PM
MM1281's Avatar
MM1281
MM1281 is offline
My understanding is that it will replace both. This is just my speculation from reading several other forums so take what I say with a grain of salt. Seems like the numbers for the F150 are something like 340 hp / 380 ft lbs with the FE at least as good as the 5.4.
So. the engine line up could look something like this. 3.5 base, 5.0, 3.5 EB and then maybe the 6.2 Boss?????
There is a ton of chat on the Mustang forums saying the 5.0 will be tuned for 400hp and around 360 ft lbs.
Old 02-19-2009, 06:40 AM
cpdorroh's Avatar
cpdorroh
cpdorroh is offline
That sounds like a logical estimate to me. If the 6.2 is going to be about 400hp/400tq, then the 5.0 won't have the same rating (especially for torque). I just hope it has enough low end torque. The 6.2 is already supposed to be a fairly short stroke engine, so logic would tell me they get 5L by shortening it even more. They could make the bores smaller, but that would seem more costly to me. Anyhow, a short stroke 5.0 that screams to an 8000 rpm redline would be fun as hell in a Mustang, but not very functional in a truck. I'm sure they will end up getting it right.
Old 02-19-2009, 03:12 PM
SteveVFX4's Avatar
SteveVFX4
SteveVFX4 is offline
well they were saying fall 2010 as the 2011 model, but maybe they will sneak it by Job #2, 2010 model?
I'm also trying to wait for the EB V6 too, and will be picking one of those 2 new motors for my next truck.
Old 02-20-2009, 05:04 AM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,221 Likes on 803 Posts
Do you think the conventional 3.5L would make it way into the F-150 line-up? I actually see the 5.0 as the base. I'm sure there will be a short supply of 4.6's and 5.4's left over to make the 5.0 an option for it's first year. I'm probably wrong, I'm sure Ford has a better plan.
Tim
Old 02-20-2009, 09:09 AM
MM1281's Avatar
MM1281
MM1281 is offline
Tim
Honestly, I dont know. I think Ford has a 3.7 v6 also that I believe that has been used in the lincolns. The 3.5 has decent hp but I believe it only makes about 250 ft lbs of torque. I do think that is better than the old 4.2 but the curve may not be favorable for truck use.
My friend has a 08 company truck with the 4.2 and it is a gas sucking dog. His old GMC with the 4.3 v6 was better on gas but it was geared much higher and was weaker because of this.
I know the 3.5 is going to make its way into the Mustang so I thought maybe it was logical to put it in other rear drive platforms like the 150. Who knows for sure. Im just hoping the 5.0 will be available in the reg cab trucks without having to buy a bunch of stuff or trim levels that some of us dont need or want. I can tell you the Mustang guys are chomping at the bit for the 5.0. They wanted it here yesterday.
Old 02-20-2009, 01:36 PM
jllang2's Avatar
jllang2
jllang2 is offline
sounds good but i don't want to wait and then not be able to get the engine i want which may be a current one depending on the power numbers and curve, i could care less about peak, i'll never use it.
Old 02-20-2009, 03:19 PM
Raider50's Avatar
Raider50
Raider50 is offline
I am not trying to single you out cpdorroh, just using your statment to help make my point. Why dose most everyone seem to thing the 6.2 is only going to have 400hp and 400tq.
From advancments in technology and its cid I would be willing to bet that it will make over 450hp easily.
A mechanic working on the Raptor R said it was making almost 500hp with only higher octane gas and a new tune. Even on a supercharged pickup a good tune can only net 50hp. So i would say expect the real numbers to be closer to 450hp/450tq. They almost have to be or it would be a shudge on the boss, and SVT name.
Quick Reply: 5.0L production start
