Changing CV Axle - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Changing CV Axle
Old 03-20-2009, 07:09 AM
high ho silver's Avatar
high ho silver high ho silver is offline
high ho silver is gaining momentum as a positive member of FTE.
Changing CV Axle
I did a search and came up short so I am asking for your help. Anyone changed out a CV axle yet on their escape. I have an 02' that has just started making a slight noise so it would be fine for awhile but I am going to go ahead and change it this weekend. I've done several before on other makes and models but not on the escape. Any tips would be helpful and pictures would be even better. Thanks in advance!
Old 04-13-2009, 04:49 PM
MMSCHWE MMSCHWE is offline
MMSCHWE is starting off with a positive reputation.
Did you replace your CV axle ?
How did it go? Anything special?
Old 04-13-2009, 06:28 PM
I bought the part and that is as far as I've gotten. I caught the flu which turned into bronchitus so I haven't felt much like fooling with it. I hope to get it done this weekend. I'll post back when I have it in.
Old 04-18-2009, 05:49 PM
Quote:
Ok for any of you do-it-yourselfers, I finally got around to changing my driver side CV axle shaft and thought I would share the process with you in case its time to do yours and you want to save some big bucks. The part only cost $75.00 and was new not rebuilt. My labor was free... Got it from Advance Auto.
The first step after jacking and supporting with jack stands was to remove the wheel to access the 32mm axle nut which you will have to spray with WD-40 or PB blaster to free it up. I used an impact gun with a 32mm socket to get it off.
The next step is to remove the steering tie rod end. Take the cotter pin out and remove the nut with an 18mm socket/wrench. After removing the nut, take the nut and flip it over and screw it back on until the end of the threads are flush with the nut so you can tap it with a hammer to knock the joint out. This little trick will keep you from messing the threads up.
The next step is to remove the lower balljoint. Take a 15mm wrench/socket and a 14mm wrench/socket and remove the bolt & nut that holds the ball joint in place.
The next step is to lower the balljoint down from its perch. Using a prybar, place it in the lower control arm hole and pry down.
The next step is to rotate the entire hub assemble (as if you were turning to the left very sharp). You will have enough wiggle room to take a block of wood or brass punch and knock the axle through the hub and pull it out.
The next step is to remove the other end of the axle shaft from the transmission. I used the same prybar and gently pryed it next to the edge of the tranny housing at the inner CV housing. There is a small lockring on the inside that will have to pop loose. Once you have it loose the axle shaft should slide out alont with a small amount of tranny fluid.
The next step is to take the new axle and insert it into the transmission being careful not to damage the seal. Once you have it in, take a piece of wood or brass punch and tap the axle keeping it straight until the new lock ring is seated in place.
Put everything back in the reverse order of removal and then you can sit back and finish off that 6 pack.
Hope this helps if you want to try it yourself. It took me about 2 1/2 hours.
Old 04-21-2009, 04:46 PM
Thanks for the photos & the detailed how-to! Nice job!
inboard CV joints "Knocking" Deebo Escape & Escape Hybrid 4 04-07-2014 06:31 AM
Rear CV Boot bunky383 2007 - 2014 Expedition & Navigator 9 12-08-2013 02:22 PM
FRUSTRATED!! Need help troubleshooting a drivetrain noise lspall 1997-2006 Expedition & Navigator 6 05-16-2011 09:05 PM
4x4 CV axle on '04-'08 models tseekins 2004 - 2008 F150 5 02-15-2009 02:32 PM
Anyone replaced outer CV joints on E4WD? aerocolorado Aerostar 15 11-22-2004 02:24 PM
Tags
2004, 2007, axel, axle, change, changing, chaning, cv, edge, escape, f150, ford, forf, remove, removing, replace, shaft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
