I have a lifter like tapping and loss of power - Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Old 05-11-2002, 01:43 AM
mustange70's Avatar
mustange70 mustange70 is offline
mustange70 has a good reputation on FTE.mustange70 has a good reputation on FTE.
Old 06-10-2002, 01:39 AM
boogning2001 boogning2001 is offline
boogning2001 is starting off with a positive reputation.
When I had a couple hundred miles on my 2001 Lightning, I noticed a noise that sounded like a lifter tapping. I took it to Ford and they said the 5.4's just make those kind of noises. Also i have noticed a loss of power. Has anyone else had this problem? Or can anyone tell me what it might be causing these problems.
01 lightning
02 f-150
94 mustang GT
Old 06-10-2002, 11:39 AM
jaymz jaymz is offline
jaymz is starting off with a positive reputation.
Well, since 5.4ls are OHC (no lifters), I would suspect this: bad coil pac (cracked and "snapping" sound from spark leak?); bearing in pulley on supercharger snout?...whatever it is, it isn't "normal" and your dealer is either clueless or lazy. Find another one who gives a ##### about his customers.
Old 06-11-2002, 12:31 AM
junehhan junehhan is offline
junehhan is starting off with a positive reputation.
Out of curiosity, have you changed your oil yet, and if you did, did it start after you changed your oil? A lot of Lightnings seem to have a wierd diesel chatter type noise start up right after the 1st oil change. Your dealer is partially right in that the 5.4 SOHC motor makes lots of wierd harmless noises. Mine makes the chatter but it goes away when the engine warms up. As far as the loss of power is concerned, that might be due to the fact that the weather has warmed up a lot lately and it's a lot more humid too, both of which kill power.
2002 True Blue SVT Lightning
-all stock and will stay stock
Old 06-30-2002, 12:04 AM
well i think it is like a diesel chatter
yes i have changed the oil well ford did it
and the sound dosnt go away its there all the time
bye the way i love the true blue i just couldnt wait
till they came out i had to get 01 right then and
i missed out on the true blue one
thanks for the info
2001 lightning 02 f-150 94 gt
Old 06-30-2002, 07:48 PM
Out of curiosity, is there any way you can record this chatter type noise and post it online? If it's the diesel chatter noise, don't worry about it because it will eventually go away. It's been 1500 miles since my last oil change and the diesel chatter noise has disappeared from my Lightning during idle. Some Lightnings lose the chatter in 300-600 miles, while other take time, but in every case except for one, the noise went away. The diesel chatter noise is considered a harmless noise and I wouldn't worry about it, unless it really did it loud. The LS1 and LS6 as well as lots of porshe engines make really wierd noises as well. If you really feel concerned about the noise, call up the manager of the service department at John Nolan Ford and he will explain to you exactly why many 5.4's seem to have that noise. He got too technical for me in his explanation and I kinda stopped paying attention when he was explaining it to me.
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 01:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 02:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 10:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 11:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
