Minimum Rotor thickness spec - OEM Fronts
Old 03-19-2009, 07:30 PM
week0019's Avatar
week0019
week0019 is offline
Anyone know the minimum rotor thickness spec for OEM front rotors on an '05 4X4 F150?
I didn't see it on the rotor although I didn't remove it.
Old 03-20-2009, 01:29 PM
wildcard30's Avatar
wildcard30
wildcard30 is offline
Minimum front rotor thickness: 1.12 inches
Minimum thickness for machining rotor: 1.14 inches
Check the rotor in 4 places.
Old 03-20-2009, 07:44 PM
week0019's Avatar
week0019
week0019 is offline
Thanks for the info wildcard!
In the mean time a friend had told me NAPA has those specs so I checked with them. They gave me the same 1.122" for the min thickness. I didn't ask them about minimum to machine.
I'm measuring 1.162 - 1.168 but the dealership tried to tell me they're under spec and need to be replaced. Bunch of crap! I knew it, they only have about 40,000 miles on them and have never been machined. Glad I checked instead of just saying ok.
Old 03-22-2009, 11:46 AM
nkapphahn's Avatar
nkapphahn
nkapphahn is offline
Has anybody else had issues with the stock rotor warping. I had mine turned at 15,000 and they are bad again at 25,000. We drive around town (by we I mean my wife, so who knows what kind of punishment she is putting the brakes through) and never tow. Just a little disappointed with the problems. Are there aftermarket rotors out there that will hold up better, or are the stock metallic pads creating too much heat. Would drilled and slotted be the way to go. Thanks
Old 03-22-2009, 12:17 PM
pb34's Avatar
pb34
pb34 is offline
Apparently the stock rotors on the 150's are known to warp quickly. I had mine cut and then decided I just wanted to replace them. I bought a pair of cross-drilled and slotted rotors on Ebay with some new pads and haven't had a problem since.
acamk37
1999 to 2016 Super Duty
13
02-19-2015 11:05 AM
mark a.
09-04-2013 10:21 PM
browntown3
2004 - 2008 F150
03-21-2012 12:03 AM
atrident
1997-2006 Expedition & Navigator
04-16-2008 10:12 AM
jetta4
02-06-2005 05:58 PM
Quick Reply: Minimum Rotor thickness spec - OEM Fronts
