Minimum Rotor thickness spec - OEM Fronts - Ford Truck Enthusiasts Forums
Old 03-19-2009, 08:30 PM
week0019 week0019 is offline
week0019 is starting off with a positive reputation.
Anyone know the minimum rotor thickness spec for OEM front rotors on an '05 4X4 F150?
I didn't see it on the rotor although I didn't remove it.
Old 03-20-2009, 02:29 PM
wildcard30's Avatar
wildcard30 wildcard30 is offline
wildcard30 is gaining momentum as a positive member of FTE.
Minimum front rotor thickness: 1.12 inches
Minimum thickness for machining rotor: 1.14 inches
Check the rotor in 4 places.
Old 03-20-2009, 08:44 PM
Thanks for the info wildcard!
In the mean time a friend had told me NAPA has those specs so I checked with them. They gave me the same 1.122" for the min thickness. I didn't ask them about minimum to machine.
I'm measuring 1.162 - 1.168 but the dealership tried to tell me they're under spec and need to be replaced. Bunch of crap! I knew it, they only have about 40,000 miles on them and have never been machined. Glad I checked instead of just saying ok.
Old 03-22-2009, 12:46 PM
nkapphahn's Avatar
nkapphahn nkapphahn is offline
nkapphahn is gaining momentum as a positive member of FTE.
Has anybody else had issues with the stock rotor warping. I had mine turned at 15,000 and they are bad again at 25,000. We drive around town (by we I mean my wife, so who knows what kind of punishment she is putting the brakes through) and never tow. Just a little disappointed with the problems. Are there aftermarket rotors out there that will hold up better, or are the stock metallic pads creating too much heat. Would drilled and slotted be the way to go. Thanks
Old 03-22-2009, 01:17 PM
pb34's Avatar
pb34 pb34 is offline
pb34 is starting off with a positive reputation.
Quote:
Apparently the stock rotors on the 150's are known to warp quickly. I had mine cut and then decided I just wanted to replace them. I bought a pair of cross-drilled and slotted rotors on Ebay with some new pads and haven't had a problem since.
Replace Rotors too? acamk37 1999 to 2016 Super Duty 13 02-19-2015 12:05 PM
rotor thickness mark a. 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-04-2013 11:21 PM
Anyone know the minimum thickness of front rotors ? browntown3 2004 - 2008 F150 9 03-21-2012 01:03 AM
Minimum rotor thickness atrident 1997-2006 Expedition & Navigator 2 04-16-2008 11:12 AM
Minimum rotor thickness F250 ??? jetta4 Brakes, Steering, Suspension, Tires, & Wheels 1 02-06-2005 06:58 PM
Tags
03, 150, 2003, 2004, 2005, f150, ford, min, minimum, rear, rotor, rotors, spec, specification, thickness, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
