What does latest flash do for me?
The latest flash preheats the injectors thru induction to eliminate stiction which causes cold start issues and after X amount of idling it exercises the variable turbo and idle rpm's. After about 3 to 4 min. of idle I can hear the rpm's change. I have not noticed any diff. in power and no change in mpg's.
<TABLE style="WIDTH: 625pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=833 border=0 x:str><COLGROUP><COL style="WIDTH: 625pt; mso-width-source: userset; mso-width-alt: 30464" width=833><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl26 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 625pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=833 height=17 x:str="'- The most recent calibration flash will help reduce coking deposit formation by improving:">- The most recent calibration flash will help reduce coking deposit formation by improving:</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Shut off EGR after 5 minutes of idling. Reduces the amount of hard to combust elements in the combustion chamber.</TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 625pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 25.5pt; BACKGROUND-COLOR: transparent" width=833 height=34 x:str="Injection timing improvements at 1100-1800 RPM (Typical range for PTO operation/Cold Ambient Protection Idle Kicker/Battery Charge Protect Idle Kicker). ">Injection timing improvements at 1100-1800 RPM (Typical range for PTO operation/Cold Ambient Protection Idle Kicker/Battery Charge Protect Idle Kicker). </TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 625pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 25.5pt; BACKGROUND-COLOR: transparent" width=833 height=34>Increased exhaust pressure / VGT Duty Cycle for APCM or PTO commanded engine speeds. Maintains heat in the combustion chamber.</TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 625pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 25.5pt; BACKGROUND-COLOR: transparent" width=833 height=34 x:str=" Higher engine temperature required for cold ambient idle kicker to switch off. Idle will remain elevated until driver input is observed by powertrain control module (PCM). Maintains heat in the combustion chamber. ">Higher engine temperature required for cold ambient idle kicker to switch off. Idle will remain elevated until driver input is observed by powertrain control module (PCM). Maintains heat in the combustion chamber. </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 625pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=833 height=17 x:str="Improved EGR throttle plate self test. Better control of hard to combust elements. ">Improved EGR throttle plate self test. Better control of hard to combust elements. </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 625pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=833 height=17>Exercises the VGT after "X "amount of idleing.</TD></TR></TBODY></TABLE>
The easiest way to find out if you have this flash is to let your truck idle for a couple minutes when its at opperating temp.The turbo will whistle for about 10 seconds then a slight rumble with a less pronounced whistle for 10ish seconds then rumble like a big block for about the same amount of time.Then start all over again.
