Does any one know about the Accel Ignition Coil Packs? I do have the 3 valve 5.4 do I need to but spark plugs if and when I replace the ignition coil packs? If anyone could help me please let me know. Thank you for your time, C
I replaced my plug around 70,000 and put the Accel #140033-8 Coil set on later. They are a direct replacememt, easy to install. I got mine from Summit for about 280 plus handling fees. If you have recently replaced plugs you shouldn't need to replace them. If they have 40K or more I would replace them but go by the TSB and have a #65600 Lisle tool on hand. They are a PITA to replace. I used the #7989 Champion plug on mine and have had no problems.
Do you need to replace them? How many miles are on the truck? No sense replacing parts that are fine. But if you do, I'd suggest Ebay coils from Global automotive. $99 for all 8. I've been running them w/o problems for more than 10K.
If you have 94K on the plugs when you change them change them by the TSB and let them soak for at least 24 hours maybe more. Buy the #65600 Lisle tool, you will most likely need it.
