What did you do to your truck today..
#31
Woke up by my girlfriend this morning who promptly told me she came down with the flu around 4am. Spend the day playin "Mr. mom". When I got a break, I`d play battlefield 1942 on the puter. I did take inventory of what I need to get the bronco rolling reliably. 1. headgasket set. 2. carb kit. 3. headergaskets and bolts 4. a new ignition coil that`ll work with duraspark. Now, I`m just waiting for my turn to "enjoy" the flu bug. Yay me..
#32
#33
#34
Pends on what you think is affordable. Spicers can be some serious $$$'s. Like when you replace front axle and both driveshaft joints. Spicers are stronger than other house brands and worth the $$$'s I think. The good house brand do have waranity but whats a free $10 joint against the cost new axle shafts or drive shaft when it lets go.
Now if it were a street driven heepie I would say use the house brand. But the way you wheel it I would get the Spicers.
#41
#42
not anything on the truck, but I did replace the water pump on the Taurus today, then replaced the front valve cover gasket, then drained and refilled the antifreeze, then drained and refilled the power steering pump. I then got to take it for a test drive. It would spit/backfire and sputter, the engine would shake like there was really something wrong, then the check engine light would come on. I was in a little bit of an emergency, so I pulled over, checked the engine over for anything that I was missing, or may have messed up. The engine took of and started idling perfect, just like a sewing machine, and when I got back into the car, the check engine light was not on.
I went ahead and drove it to the location where a buddie's car had died (where I was heading at the time it started acting up) When I turned around to get to the other side of the road, it started acting up again and the check engine light came on again. I shut it off behind the other stalled vehicle, and when we were done, I started it back up again, it spit and sputtered a few times, but as I got closer to town it got better.
I followed my buddy into Autozone and they said that it was cylinder #1 misfiring, I figured since I was running the tank really low, that I might have been pulling water off the bottom of the gas tank. I picked up a bottle of Lucas injector cleaner and two bottles of HEET. I put them in and put in a full tank of gas. I didn't have any more problems the rest of the way home, but I had problems once I started heading out to Justin's house. I helped Justin fix his steering column, and put it back together, then I headed home. It stumbled several times on the way home. I then checked spark plug wires, and vaccuum lines, and took it for another drive, I drove out to I-70 and back, and it never did spit,sputter, or backfire, it ran like a champ and the check engine light stayed off. Guessing my theory about water in the fuel might have been right. At least I am hoping.
