Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
2002 Harley Davidson F-150 Top Speed???
Old 06-18-2002, 03:54 PM
Hodo03's Avatar
Hodo03
Hodo03 is offline
Post 2002 Harley Davidson F-150 Top Speed???
Does anyone know the top speed and 0-60 time for the 2002 Harley Davidson edition of the F150 Supercrew truck? I know the horspower and torque, I just need these number to decide if I really want to buy one.
Ford refused to provide the information.
Old 06-20-2002, 05:37 AM
treadwheeler's Avatar
treadwheeler
treadwheeler is offline
I am looking similar information about tech spec's on the '02 HH as well. I am close to buying one and info as to specific's about the model are limited at best. What have you expirienced with pricing at this point? I've found several with all 4 available options at one dealer advertising $33,400. Given that it seams all incentives out right now footnote "does not include Harley Hauler", and a sticker of $38,000 +\- it's not a bad starting point.
Do you know what the difference is in the horse power rating between the Lightning and Harley. 340 vs. 380? Just a chip & airflow, or because the L comes from SVT maybe a cam or heads difference as well?
If they would just build the L in a SuperCrew model my search would be over since I need a 4 door but want the power plant too!
Old 06-20-2002, 08:40 AM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
The difference is the size of the boost pulley and the programming. I've programmed several chips for HD F150s with a Lightning boost pulley, surprises the heck out of some Lightning owners.
Old 07-09-2002, 06:12 AM
treadwheeler
Thanks for the info/reply.
Can you tell me or confirm other differences in the HH and L. Best I can tell -
Bilstien Shocks all four corners
Rear Sway Bay 23mm. No bar on regular supercrew or HH
31mm front bar. Same size or is it larger diameter?
12" front & 13" rear disc. HH has 4 wheel disc like all others. Are the L's larger diameter? Any difference in calipers - # pistons, etc.
Ride hieght - HH indicates 1" or 1.5 lower than stock SC. L same or lower?
I will probably be picking up a HH next week and trying to get some ideas of where I want to start with upgrades & mods. I have read through some of the other strings and have seen some comments on chips and exhaust. Will probably do the K&N and Flowmaster pretty quickly.
I would like to work towards getting about 400HP in the most economical fashion, but want to do it right.
If the chip in the truck is re-programable to L specs is there a reason to go aftermarket? Will any SVT dealer reprgram? Can I order the L supercharger pully from them as well or will they only allow orders from L owners. I installed a set of chrome replica L wheels on a friends '01 L and they would not let me order another set of centercaps with out proof of ownership of an L. I have since sent the originals out to be chromed.
Thanks for all the info.
TW
Old 07-11-2002, 11:26 AM
junehhan's Avatar
junehhan
junehhan is offline
Old 12-04-2005, 06:59 PM
windmedic's Avatar
windmedic
windmedic is offline
Stock rev limitter is 130 mph for my 2002. Had a new 350z close till then.
Old 05-03-2020, 05:08 PM
Tymothy Bradsteen's Avatar
Tymothy Bradsteen
Tymothy Bradsteen is offline
2002 f150 harley davidson supercharged
So im not sure on the top speed of the vehicle but i have gotten mine to reach 130 before I let off before and 0-60 with upgraded shift points cold air intake and upgraded pulley then a x4 power flash tuner i got my 0-60 in about 4 seconds
Old 05-03-2020, 05:22 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,576 Likes on 1,054 Posts
I'm sure he's been waiting 18 years for your answer to decide if he should buy one or not.
rockrig4x4
11-11-2015 03:03 AM
commandersander
08-22-2008 11:57 PM
jarepackard
08-11-2004 01:31 AM
kopp0041
06-16-2003 07:06 PM
STUDENT
10-15-2002 08:40 AM
Quick Reply: 2002 Harley Davidson F-150 Top Speed???
