You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Does anyone know the top speed and 0-60 time for the 2002 Harley Davidson edition of the F150 Supercrew truck? I know the horspower and torque, I just need these number to decide if I really want to buy one.
I am looking similar information about tech spec's on the '02 HH as well. I am close to buying one and info as to specific's about the model are limited at best. What have you expirienced with pricing at this point? I've found several with all 4 available options at one dealer advertising $33,400. Given that it seams all incentives out right now footnote "does not include Harley Hauler", and a sticker of $38,000 +\- it's not a bad starting point.
Do you know what the difference is in the horse power rating between the Lightning and Harley. 340 vs. 380? Just a chip & airflow, or because the L comes from SVT maybe a cam or heads difference as well?
If they would just build the L in a SuperCrew model my search would be over since I need a 4 door but want the power plant too!
The difference is the size of the boost pulley and the programming. I've programmed several chips for HD F150s with a Lightning boost pulley, surprises the heck out of some Lightning owners.
Thanks for the info/reply.
Can you tell me or confirm other differences in the HH and L. Best I can tell -
Bilstien Shocks all four corners
Rear Sway Bay 23mm. No bar on regular supercrew or HH
31mm front bar. Same size or is it larger diameter?
12" front & 13" rear disc. HH has 4 wheel disc like all others. Are the L's larger diameter? Any difference in calipers - # pistons, etc.
Ride hieght - HH indicates 1" or 1.5 lower than stock SC. L same or lower?
I will probably be picking up a HH next week and trying to get some ideas of where I want to start with upgrades & mods. I have read through some of the other strings and have seen some comments on chips and exhaust. Will probably do the K&N and Flowmaster pretty quickly.
I would like to work towards getting about 400HP in the most economical fashion, but want to do it right.
If the chip in the truck is re-programable to L specs is there a reason to go aftermarket? Will any SVT dealer reprgram? Can I order the L supercharger pully from them as well or will they only allow orders from L owners. I installed a set of chrome replica L wheels on a friends '01 L and they would not let me order another set of centercaps with out proof of ownership of an L. I have since sent the originals out to be chromed.
