2002 F150 Codes P0303, P0316, and P0171 - Ford Truck Enthusiasts Forums
Old 03-18-2009, 04:15 PM
turner2005 turner2005 is offline
turner2005 is starting off with a positive reputation.
The issue started about three days ago with a slight hesitation and bumpy acceleration. The check engine light came on and then went off. The vibrations have been getting worse at idle but are smooth sometimes as well. I went to the auto parts store and had them scan for codes and I received codes P0303, P0316, and P0171. Does anyone have any suggestions? I added some Lucas injetion cleaner, and am going to install a new fuel filter, and spark plugs tommorrow. Am I on the right track or should I be looking somewhere else??? Any help would be greatly appreciated. Thank You!<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Old 03-18-2009, 04:41 PM
whimsey whimsey is offline
whimsey is starting off with a positive reputation.
P0303 is a misfire detected in cylinder 3. P0171 is system too lean, bank 1. I don't know what P0316 is. It might be a generic code that covers multiple symptoms. Try using your computer search engine. I did that with an unknown code I got with known codes and it turned out to be a generic catch all code.
Whimsey
Old 03-18-2009, 04:45 PM
Autozone says that the P0316 means a Crank Sensor Condition. I have also seen on this site that it means Engine Misfire Detected on Startup (First 1000 Revolutions). I am not sure which is correct. Does anyone know the correct definition???
Old 03-30-2009, 08:23 PM
chadptrson chadptrson is offline
chadptrson is starting off with a positive reputation.
My scanner interprets it as "means Engine Misfire Detected on Startup (First 1000 Revolutions)"
I am troubleshooting the same codes (different cylinder PO301, which is more covienent) replaced the spark plug and it went away for 15 miles, now back with PO301 and PO316 again...
Next work is Coil Pack, then Fuel Filter, if that doesn't solve it. Let me know what you find, and I will do the same!
Old 03-31-2009, 09:43 AM
What I found
Chad,
I went ahead and changed all 8 spark plugs since I had about 94,000 miles on the truck and they are recommended @ 100k. The spark plug on cylinder 3 was definetly fouled. I also found that the coil pack on this cylinder was bad. After changing all this as well as the fuel filter my problems went away. I hope this helps you. Good luck!
Old 03-31-2009, 10:22 AM
Troubleshooting Bad Coil Pack
How did you determine that the Coil Pack was really bad? Or did you just assume like I am that becasue the code was for that cylinder, it had to be bad?
I have 108K on the truck so I think I will replace all the plugs as well...
Too bad #4 and #8 are so far back in there :>
Chad
Old 06-14-2010, 11:44 PM
Planman67 Planman67 is offline
Planman67 is starting off with a positive reputation.
Talking More Codes
We had some serious rain here today and my 02 F150 supercrew 5.4L Was doing fine until finally this one flooded area. It started running really rough and then the SES light came on. I am used to the rough part since I have a COP that occationally acts up and doesn't come on. Well now it is off for good. I had Autozone pull the codes and it hit P0305 and 0316 Basically, #5 COP and it says Crank sensor condition. Crank sensor defective? I was able to quickly replace the #5 COP but my SES light is still on. Does it reset after a while, or should I disconnect the battery for 10 minutes or so and then see if the crank sensor corrects itself and the SES light stays off? Thanks.
Old 06-17-2010, 07:44 PM
azfisher azfisher is offline
azfisher is starting off with a positive reputation.
I had the same errors, changed out the COP and reset the codes. It has been running fine for 2000 miles with no returning codes. The code should go away after a while but can Autozone reset it for you?
Old 06-18-2010, 10:49 AM
I just unhooked my battery and it reset the light, driven for 3 days and actually runs better than before. I have had a COP acting up for about 2 years but every time I take it in they cannot find the one that was acting up. It never kicked the SES light so it was intermitten. Thank you for your response.
351 Windsor Build Micbruff 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 23 11-05-2014 09:17 PM
T-Series truck Vin # catdieselmeister Large Truck 3 04-28-2014 06:23 PM
newbie F250 5.4L 3V HELP!!! ikaro 1999 to 2016 Super Duty 3 11-27-2013 02:07 PM
Crazy loud gear (?) whine at 25mph + Lex2002 1999 - 2003 7.3L Power Stroke Diesel 47 09-23-2013 10:53 AM
Krewat- There are OBD-II 2-valve V-10's Wolfboro Modular V10 (6.8l) 21 07-20-2012 02:26 PM
Tags
2002, 2003, code, codes, condition, crank, detected, engine, f150, ford, misfire, p0303, p0316, po171, po303, sensor, startup, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
