You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I just filled up with my first tank of b20. I plan on running this for a couple of tanks, changing the fuel filter, and then go up to b50 and maybe b100.
I think I have noticed less smoke, dont know if it is me or the bio, but I'm excited to step up to higher blends. Something about just loves the idea of bio.
What should I know be aware of?
Awsome. I'm excited, I just want to make sure I don't do any damage to the truck. I read that slowly upping the biodiesel percentage is the best way to go. I have read that the 7.3 loves bio which is great
I run 100% bio and I am always amazed at how clean my lube oil stays. I have approx 2K miles on this oil and I can still see the writing on the dip stick.
Tom
__________________
93 F-250 7.3 Banks turbo, 3.5" exhaust 4" ram air K&N filter E40D 4.10. Pyro, boost, & tranny temp gauges. Tru Cool 28,000 GVW trans cooler. 100% BIO
Be aware of the gell point though, think Fabman said that as long as it doesn't get below zero 50% is safe. You might want to have different ratios in small sealed containers so you can track which ratios are good at your temp... different oils have different gel points, and it might varie from batch to batch unless you are getting it always from the same sources... Does give an idea though.
__________________ Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!! 2002 TDI New Beetle - also likes Bio.
I just filled up with my second tank of b20 today. My average mpg 16.5
I was getting ~12 over the winter so I don't know how much of that is the b20 blend or how much is my driving/fixed a couple things on the truck but this is awsome I'm stoked with the mileage numbers. Can't wait for a couple more weeks to get some b50 and b100
i have a quick question. what is b20,b50,b100? and also do you guys get bio at the sevice station. I am just wondering i am new to all this. Thanks
The number after the "B' is the percentage of biodiesel in the "mix". B-20 would be 20% biodiesel and 80% dinodiesel. I make all my own biodiesel.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
Always hard to compare mileage on diesel's with cold weather. I know mine doesn't like it. Once the temp gets above 40 and the EBPV doesn't work, my mgp goes up 2-3 mpg. I can say that I didn't notice any difference driving across the stae except for the smell and maybe a a tab quieter.
Well, i have a 99' F-350 with the 7.3L Diesel Super Duty and have noticed the same thing...normally it gets 14-15 mpg and right now i'm getting a flat 11.6 no matter who's diesel i buy, or injector lubricant additives i put in. From what i understand, if you have the ebv removed (with a computer chip in its place) sometimes you can get better mileage (but wouldn't recommend it.) I can also tell you if you keep the block heater plugged in, you dont have to completely warm it up, just long enough for the coolant to really start cycling.
sknaggs185
Reason: added info
You are good to go. All Fords after 93-94 already have biodiesel ready fuel lines, so no changes are necessary!
__________________
