4R70W transmission
on
4R70W transmission
I posted on the transmission forum,...
https://www.ford-trucks.com/forums/8...patibilty.html
but may be you guys would know, what year Ford trucks can i get a transmission from to replace the one in a '97 4.6litre?
thnx,
Frank
thnx,
Frank
thnx,
Frank
thnx,
Frank
JL
on
Your '97 model uses a VSS for speedometer input,so you have to get a trans that has the gear teeth cut into the output shaft to rive the VSS. That limits you to '97-'02 model 4R70W's for the most part. You'll want one from a modular(4.6 or 5.4L) not a 5.0,3.8,or 4.2L engine-those all use a different bellhousing bolt pattern. Best to get one from '98-up due to upgraded internals,but you'll need to do a bit of parts changeover or a harness repin to work properly with the new electrical on the '98-up models.
JL
JL
Thanx,
Frank
Ok, then that widens the search a lot more. I can understand the harness repin but that means I need a section of the harness (or at least the connector) from the donnor truck right? Is there more to it when you say parts change over or are did you just mean getting the wires to match up?
Thanx,
Frank
Thanx,
Frank
JL
JL
JL
on
Never easy!
Johnny,
Any chance the info you gave me was backwards 97 vs 98?
As luck would have it, I found a lower mileage '97 transmission, only to find that my truck, a 97 , is looks to be wired like a 98. The truck has a 12pin MLPS harness.
Do you know if the solenoid pack connector/harness would appear to be the same with respect to colour code? ie both connectors would have the same colour wire goin to the same pin in their original configuration?
I'm to get a schematic,......
Frank
Frank
Johnny,
Frank
Frank
JL
on
Happy ending.....
The yard swears it came out of a '97 F150. I got hold of the schematics for both a '97 and "98 and was able to determine that solenoid pack wiring was identical on both the replacement and the original transmission. In the end it was simple plug and play using my original MLPS.(Ford must have switched MLPS at some point during the "97 model year?).
Most frustrating part of the whole job (besides laying out the cash!) was having to drop the replacement transmission again because I didn't seat the torque converter all the way in.
Truck runs great, and the yard gave me a 90 day warranty on the transmission that only had 114,000 kms on it.
Thanx again!
Frank
Thanx again!
Frank
MLPS Confusion - Possible explanation
I am changing out the transmission, transfer case, and engine in my 97 f150 xl. I pulled all this stuff out of a 97 f150 at the junk yard. I rebuilt the motor and I am using the tranny and t-case as is. I am having the same confusion that you had. The transmission from the junk yard has the old style, 8 pin, MLPS with the 98+ bulk head connector; and the tranny on my truck has the new style, 12 pin, MLPS with the 98+ bulk head connector. I am thinking that, as you said, Ford switched to the updated transmission harness in the 97 model year; which is why my truck has the newer electronics. I think whoever owned the truck in the junk yard probably installed a 98+ model tranny, converted their 97 wiring harness, and installed their old MLPS. So, just like you, the swap will be plug and play for me after I change the MLPS. I think it's a reasonable hypothesis...
