Belt and Power Steering Pump Squeal
OK guys, I have searched over the forums, and if this issue has been addressed, Please let me know. My son has a 1986 F250 XLT Lariat with a 351W, AC and Automatic. It has approx 150K miles. Recently, he complained the engine was whining and squealing at High RPM.
I looked at the belts, and replaced. I went through several process of elimination attempts to verify the squealing was coming from the Power Stearing Belt/Pulley. I had tried different belt tensions to try to eliminate.
After my help, or lack thereof. he got a wild hair and changed the pump. The squeal is still there. Sometimes at start-up others once he gets the engine to 28-30,000 RPM. The belt alignment is clean and straight. My only guess is the Pulley/Sheave is worn on the inside. If I run a finger inside, there is a subtle groove worn into the metal. Is this a likely cause for "Belt Squeal"? I really do not like to use belt dressing, but the kid did and it stops for a few minutes when he uses it. Once it gets hot. I think it evaporates. but it has left the belt sticky to the touch.
Is there a easy cure for the problem. I am not sure changing the Pulley would make it stop. Plus I am having a hard time locating a "NEW" one. A junkyard could work, but it may be just as worn.
Any guidance would be appreciated. Coles DAD
I had an 85 with a 351w h.o. that had a belt squeal problem. Check your fan clutch first, if it's good then you might want to think about switching to a serpentine pully system. I did and it solved my problem. There should be plenty left in the wrecking yards. Just be sure the donor vehicle didnt take a front impact.
on
Does the fan turn freely with the engine off and cold, when you turn it by hand? Try wiggling it back and forth. If you get sideways movement, the bearings could be worn.
bluemtn95ford
25
02-10-2013 11:30 PM
