2001 explorer freeze plug replacement - Ford Truck Enthusiasts Forums
Old 03-16-2009, 02:56 PM
96expblk 96expblk is offline
96expblk is starting off with a positive reputation.
I have a 2001 explorer v8 with auto. transmission. On cold mornings before the car has even been started, I can see a spot on carport where antifreeze has leaked out. On warmer days, nothing leaks. When engine is warmed up, nothing will leak out. It just seems to leak out overnight when it is cold weather. I suspect it might be a freeze plug leaking. Does anyone know how hard it is to replace the freeze plugs? Is it something that a garage would have to do?
Eddie
Old 05-02-2009, 04:54 PM
98explorerltd 98explorerltd is offline
98explorerltd is starting off with a positive reputation.
Ugh. I haven't done it yet, but this is a difficult fix. To get to the freeze plugs, one must remove the transmission. I think estimates for this fix is around $500. Knowing that little seeps out (because of the different metals, cold will cause contraction and gaps for coolant to seep out), i just keep tabs on the levels, and add when appropriate.
Old 05-03-2009, 10:12 AM
Bear River Bear River is offline
Former ******
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
You can replace freeze plugs with rubber plate plugs. They consist of two plates of steel (usually stainless) with rubber sandwiched between them. A bolt connects the two plates together and when you tighten the bolt, the rubber expands out the sides, forming a tight seal. If you make sure you replace the coolant on a regular basis, these plugs seem to hold up extremely well. If you neglect the system, the metal can corrode even though it is stainless.
Old 05-03-2009, 07:44 PM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
Before doing a freeze plug, you should narrow down where the leak is. It could also be a hose clamp leaking or something else.
freeze plugs popping out chickenlegs 1999 to 2016 Super Duty 14 04-13-2015 11:29 AM
351w Cam Freeze Plug Help Needed Pincheweddo Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 8 03-10-2014 10:08 PM
throttle body freeze plugs leaking szealuss 1987 - 1996 F150 & Larger F-Series Trucks 0 10-17-2010 11:40 AM
replacing freeze plugs ackusackus 1973 - 1979 F-100 & Larger F-Series Trucks 4 10-16-2002 09:56 PM
Coolant leak from freeze plug robl Explorer, Sport Trac, Mountaineer & Aviator 3 04-29-2002 05:20 PM
Tags
2002, 91, 92, explore, explorer, f150, ford, freeze, location, plug, plugs, replace, replacement, sport, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
