Volare install templates
Let me know your mailing adress and I will send you a copy of the patterns I used when I installed the volare ifs in my 56.Someone gave the pattern to me several years ago at the F100 run at the Grand in Pigeon Forge Tn. I have used them 4 times myself and given copies to others several times. I will make copies on thin paper that can be folded to mail.You will probably want to transfer onto stiffer material to mark your frame. I have been planing to transfer it to thin sheet-metal eventually. I recommend that you cut "inside" the marks and grind the frame to fit the volare crossmember.Also , check the height at which most 53-56s ride with the volare to be sure you are satisfied with the height.While the volare is adjustable up and down by turning a big bolt on each side,if you go more than an inch ,at most, up or down from stock the ride and handling suffer greatly.If I use a volare again , I will consider lowering the pattern on the frame, which would raise the front of the truck.Happy motoring to you & yourn.Thom
cost me 2 bucks a page (3 pages) to copy and 5 bucks postage to send the last set.
As these templates were 'sold' to someone, it is unethical to post them free to all, and I don't have a scanner that can scan that big a document anyhow.
Sam
Hey Sam,
That's cool if you don't want to send any out to fellow members. I had read a few previous post where some members were generous enough to offer copies so that's why I put out the call for a set. I had 2 responses and offered to pay all costs to send them but unfortunately I never did recieve any. As stated in my 2nd post on this thread I'm on a tight budget so I'm just looking to save a few bucks.
Scott
Scott
Hey Sam,
Scott
Scott
I don't think its fair to 'expect' anyone to do this gratis (which was the tone I detected, altho it may have been incorrect).
and it takes me time to get to the copier to get this done. I will be gone the next three weeks..
Sam
Actually, the patterns I have were probably not "store-bought" patterns. The gentleman who gave them to me several years ago and I talked about an article in a truck magazine showing making your own patterns from wire, like long gas-welding rod and transferring it to the frame. I think he had already done so.I lost his name and number a long time ago, but if I remember correctly he had a yellow 54 truck and was from South Carolina. I have used the patterns on four 56 trucks so far and loaned them out a couple of times.I will copy the pattern onto something like the paper a brown grocery bag is made from.Maybe if I copy and send them to one person at no charge that person could do the same and pass them on to someone else , like a chain letter. I will get one in the mail tomorrow or the next day.
About the patterns...They use existing holes in the frame to locate in the correct location. I believe it is a steering box bolt hole at the rear , which 53-56 F100's have on both sides , by the way. The front uses a hole left when the front spring shackle is removed , I think. It will be obvious when you hold the pattern up to the frame, I hope.There is some trimming of the back of the front crossmember required also , which you will see when cutting the frame rails.I try to cut very close by the pattern the do some grinding for a tight fit for welding.I have let several people drive my 56 while I rode " shotgun". All have been impressed with the ride and handling.I may do the same at the up-coming event in Pigeon Forge.Thanks
I got mine as a gift from an FTE member 10 yrs ago, and I have sent out 3 copies as gifts.. (aka, pass it on, like a chain letter.. but you can't do this forever..).. these are copies of purchased templates.
I used a cutoff wheel to cut the chassis, and grinder to clean it up.
here is the article John Niolon did, updated with my pictures using the templates.
NOTES ON A VOLARE FRONT CLIP INSTALL ON A
Sam
Sam
I am willing to send copies of templates for the expense cost. I've already done the free copies. (and my wife thinks the budget isn't for free to others).
Sam
Sam
Scott
busted 55
03-09-2015 08:03 AM
iwanaflattie
04-07-2014 01:49 PM
jniolon
07-17-2012 03:54 PM
