99 F250 Static in Radio Speakers - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-16-2009, 04:36 AM
jrodftch jrodftch is offline
jrodftch is starting off with a positive reputation.
Ok guys need your help here Ive thought about replacing all the speakers but wana see if anybody has an Idea why all the speakers have static in them. It doesnt matter if the truck is running or if the truck is off the static is still there. Im thinking it could be a ground problem but dont know where to start looking. Also the radio does not stay on with the delay when the key is cut off it turns off as soon as the key is cut off. Has anyone else run into this problem?
Old 03-17-2009, 09:34 PM
horsepuller's Avatar
horsepuller horsepuller is offline
horsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputation
Moved from 2011 F100 forum.
Welcome and thanks for joining us at FTE!
Old 03-17-2009, 09:44 PM
CruiserClass CruiserClass is offline
CruiserClass is gaining momentum as a positive member of FTE.
I don't think the '99 has the "stays on until door opened" feature on the radio. Mine didn't.
As for the ground issue, its a possibility. When I replaced my stereo I found the factory ground was tiny and had a break inside the insullation, causing intermittant noise.
You can run another ground wire for the head unit, but before you do that try running a ground strap from the bottom of your cab to the frame. Its easy and cheap and may clear up the issue without having to run another wire.
Old 03-17-2009, 11:54 PM
DAVE67FD's Avatar
DAVE67FD DAVE67FD is offline
DAVE67FD is gaining momentum as a positive member of FTE.
Has the truck always done this since you have owned it? Does it do it no matter where your parked? I wouldn't suspect the speakers as all of them are doing it. Try cruisers idea as a ground loop maybe occuring. The radio itself could also be defective. Does it do it with a CD/Tape or different stations?
speaker static noise with key off bashby 1987 - 1996 F150 & Larger F-Series Trucks 9 09-19-2015 02:37 PM
Electrical noise in dash 1974F100 Excursion - King of SUVs 14 07-02-2015 02:47 AM
Any suggestions for nasty AM radio static? GuitarJesus 1987 - 1996 F150 & Larger F-Series Trucks 42 10-11-2014 08:37 PM
2003 F250-Good Aftermarket Radios? Subzero68 1999 to 2016 Super Duty 13 06-10-2014 03:10 PM
Speaker Static per935 1997 - 2003 F150 1 08-30-2013 07:49 PM
Tags
99, f250, ford, radio, replacing, speakers, static, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
