Go Back   Ford Truck Enthusiasts Forums > General > General Automotive Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 03-16-2009, 02:10 AM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation
67 Galaxie build (dial up warning several pics)
I haven't posted about this car in a while (since it's not a truck duh LOL) It runs now, and hopefully it will be driving this week. gonna take it up and race it May 3rd. Plan is a street/strip car just to have some fun with. Bodywise it's not perfect, but fairly solid as is the frame although it does have some rust on the frame but not through anywhere.
Here is a few pics
Basically I have dropped a 390 in it that came out of a friends mud racer, with a C6 I built for him. Shoved a set of 3.63 gears with a traclok in the rear.
Don't have any pics that really show them but the headers are Crites with 2" primary tubes with 3.5" collectors.
AS you can see the cooling system is a 28x19 alum dual core radiator, fan wasn't on for the pics but is a 3000cfm unit.
Fuel system consists of major overkill for this motor but when I get around to it I will build another stroker big block probably. fuel pump is a mallory 250gph, with a BG regulator, 16 gallon fuel cell, with AN-10 line through a summit 10 micron filter, then to the pump, from there 1/2" alum line to the regulator then -8 line to the carb.
Right now the rims are torque thrust 14x7 on the front. with the rears being currently 15x8.5 centerline convo pro's with BFG comp t/a, but I just bought a set of 15x8 weld prostars with a set of 28x11.5-15 Mickey Thompson ET streets and will put some cheap street tires on the convo pros for cruising. (don't have pics of the new tires yet, cause they havn't gotten here yet LOL)
Also since this car had sat for almost 20yrs in a Kansas farm field it had some electrical problems so I put in a switch panet to wire up the MSD ignition and gauges, fuel pump and fans.
You can see the autometer procomp gauges, also have a 5" automotor tach with shift light.
Some of the other stuff is I converted it to manual brakes with disk on the front. I have fiberglass race seats with covers and although not installed yet 3" 5pt racing harness, a B&M quicksilver shifter.
Like I said the body work isn't even good, and that isn't really my strong suit anyway although the body is solid. And this is going to be one of those never ending projects to keep me busy, first order of business was to get it running so I could cruise and race it some, and hopefully get to take it up to the goodguys heartland nationals car show this year just for fun.
__________________
Rob
Dying's not so bad
It's living that will kill you off
  #2 (permalink)
Old 03-16-2009, 02:25 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
If you need a grille, FTE member gangstakr just found a NOS original in an old body shop.
He can be found in the 1961/66 forum.
__________________
Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
1934 Packard V12 Convertible Victoria // 2008 Fusion S // 2008 Edge SEL.
  #3 (permalink)
Old 03-16-2009, 02:29 AM
My grill isn't too bad actually but thanx. (always good to hear about that type of stuff just in case) I could use some new taillight lenses and front turn signal lenses, mine are cracked although usable.
__________________
Rob
Dying's not so bad
  #4 (permalink)
Old 03-16-2009, 02:56 AM
BTW for those that didn't see the old thread, this is what it looked like the day I brought it home
__________________
Rob
Dying's not so bad
  #5 (permalink)
Old 03-16-2009, 06:32 AM
Ford Parts Guru
Quote:
C7AZ13208A .. Right Parklamp Lens / Obsolete
KINSEL L/M in Beaumont TX has one: 800-816-2894
BOWMAN SALES & SERVICE in Bowman ND has one: 701-523-3257.
KLIMESH MOTOR SALES (ex-dealer) in Calmar IA has one: 563-562-3241.
C7AZ13209A .. Left Parklamp Lens / Obsolete
KLIMESH has four.
BOWMAN has one.
FREESE MOTORS (another ex-dealer) in Monticello IA has one: 319-465-3541.
2) C7AZ13450C .. R/L Taillamp Lens / Obsolete
Fits all 1967 Ford Galaxie/Custom/LTD/XL's except station wagons.
Surprisingly, no Ford dealer or obsolete parts vendor has any.
You can soak 'em in hot water, fill in the cracks with clear epoxy...then polish them up...with tube toothpaste...I kid you not!
FYI: KLIMESH, FREESE, BOWMAN & KINSEL have tons of obsolete parts.
__________________
  #6 (permalink)
Old 03-16-2009, 06:51 PM
mercman86's Avatar
mercman86 mercman86 is offline
mercman86 is starting off with a positive reputation.
I love those galaxies! Looks like a your doing a good job, keep up the good work and have fun with it!!
__________________
Alex
2004 F-150 XL 4.6 Triton
1966 Falcon Ranchero 200ci I6
1999 Taurus SEL 3.0 24V
2007 Viking RV Pop-UP
  #7 (permalink)
Old 03-16-2009, 09:48 PM
finally got the front tires changed over to the torque thrust wheels so I could put all the tires on it, here is a pic so you can see it in one pic. Notice the artwork by the local 8 yr old delinquents LOL. At least I still need to strip it down and primer it this year (although will probably end up going to the track before that gets done.)
__________________
Rob
Dying's not so bad
  #8 (permalink)
Old 03-17-2009, 04:51 PM
Well finally got to take it around the block today, if I remember and understood the guy I bought it from correctly this is the first time in over 20yrs this car has moved under it's own power. Yep lots of little stuff still needs fixed but it runs and moves so there is light at the end of the tunnel.
__________________
Rob
Dying's not so bad
  #9 (permalink)
Old 03-21-2009, 08:10 PM
Flexfuel-Dave's Avatar
Flexfuel-Dave Flexfuel-Dave is offline
Flexfuel-Dave is starting off with a positive reputation.
Cool looking car!
If a repaint is in the future, any idea on a color yet?
These were pretty cars! Almost like them better than the 1963.
Those Torque Thrust wheels were always expensive, but man are they great looking! They always look great on the cars from the 1960's.
  #10 (permalink)
Old 03-21-2009, 08:33 PM
Dave I have been checking out paint and stuff and since it was blue originally and I did put in blue safety harnesses and I can get gallons of it reasonable I am going to shoot it with handicap blue paint LOL. actually like I said I can get a gallon of rustolem handicap blue paint for under $30 and it will give me a chance to play with my first paint job cheap enough that if I mess up it's no big deal and then if I want to get fancier later I will have the experience behind me. besides I actually know of another car locally painted with implement paint by rustoleum and unless he tells you you would never realize it was cheap paint.
__________________
Rob
Dying's not so bad
  #11 (permalink)
Old 03-21-2009, 08:35 PM
Oh and since i mentioned the safety harness's here is an interior shot. When it warms up I need to wire brush and clean the front floorboards and coat with POR-15 then going to carpet it with something later, probably astro turf type of stuff, durable and easily cleaned.
__________________
Rob
Dying's not so bad
  #12 (permalink)
Old 03-21-2009, 09:04 PM
71dusterdan's Avatar
71dusterdan 71dusterdan is offline
71dusterdan has a brilliant future 71dusterdan has a brilliant future 71dusterdan has a brilliant future 71dusterdan has a brilliant future 71dusterdan has a brilliant future 71dusterdan has a brilliant future 71dusterdan has a brilliant future 71dusterdan has a brilliant future 71dusterdan has a brilliant future 71dusterdan has a brilliant future 71dusterdan has a brilliant future
Sweet Monster, what a beautiful car, okay it isnt beautiful to anyone other than a car guy. It looks pretty dry, and clean. So it is a beautiful foundation. Keep them coming. Dan
Ps Bill nice work on the parts scrounging, your reputation is well deserved!
__________________
one sick puppy
Quote:
Originally Posted by 71Dusterdan
WOO WOO Shake wife at weiner
Hey i finally posted a gallery check it out.
__________________
snl#16
Tims' minions - snatch and grab expert
  #13 (permalink)
Old 03-22-2009, 06:41 AM
wendell borror wendell borror is offline
wendell borror has a great reputation on FTE. wendell borror has a great reputation on FTE. wendell borror has a great reputation on FTE. wendell borror has a great reputation on FTE.
It's looking good, however, I believe I would run a set of 30's or 4:10's to keep a car of that weight in it's power band easier. I saw a 65 or 66 galaxy clean up on pinks on one episode, it was blue. With the fastback styling, they make a good looking race car. The 390 can be built and stroked using 428 and 427 parts for a mean runner. The 390 is no sloutch in it's self. Throw on some primer and a few racing decals and it's pinkable. I like the fastback galaxy's and the 64-65 mercury comets, they were fastbacks, they would all make cool strip cars. Good luck on the project!!!!
__________________
2009 FORD RANGER fx4 off/road, 5-speed manual, torson diff and rancho's!
2008 mercury mariner 4x4 V-6, automatic.
1987 jeep wrangler, 258, 5-speed
  #14 (permalink)
Old 03-22-2009, 07:31 AM
Ford Parts Guru
If you think NOS trim parts are hard to find for 1967 Galaxies, just wait till you own a 1964/65 Comet.
Mouldings, grilles and etc. are non existant.
These two Comets are very collectible today, prolly the most sought after post war Merc's after the 1949/51's.
These Comets could be ordered with the 289 271HP Hipo engine, VIN engine code: K.
__________________
  #15 (permalink)
Old 03-22-2009, 09:49 AM
tjc transport's Avatar
tjc transport tjc transport is offline
oh no, not again!!
tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation.
one thing to think about with the rustoleum paint Rob.
it does not have UV blockers in it, so it fades in a few years.
but rustoleum did come out with a clear coat that has UV blocker in it last year.
i am going to use it on the falcon if it ever gets done.
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of way too many fords.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
