Aiming Headlights - Ford Truck Enthusiasts Forums
Aiming Headlights
Old 03-15-2009, 05:35 PM
kdy72601's Avatar
kdy72601 kdy72601 is offline
kdy72601 is starting off with a positive reputation.
Aiming Headlights
anyone know if they make a speical tool for adjusting headlights i got new headlights but thier still little outof wack and cant get a rachet on it any more and cant find a 4mm wrench?
also does any one have any tips or tricks to aim head lights?
thanks
Old 03-15-2009, 09:44 PM
fmr9 fmr9 is offline
fmr9 is gaining momentum as a positive member of FTE.
I got one 1/4 in drive metric socket that fit fine, at Auto Zone for about $2.50
Old 03-16-2009, 12:50 AM
Dirt racer's Avatar
Dirt racer Dirt racer is offline
Dirt racer is starting off with a positive reputation.
They do make special tools for aiming head lights. I used them when I used to work at a Ford dealership. A cheaper way though is to pull up to a closed garage door at night with the headlights on and line them up with the door so they are even. Don't get them too high though.
Old 03-16-2009, 12:52 AM
truckertom21 truckertom21 is offline
truckertom21 is starting off with a positive reputation.
Quote:
6 point or 12? i have the same problem
Old 03-16-2009, 06:13 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
For adjusting the height with the rod that sticks up, I use a small pair of visegrips. Don't put them too tight though. Its worked fine for me.
Old 03-16-2009, 08:46 AM
Quote:
I think it is a 12 point. My regular metric sockets are 6 and they would not fit, so I'm assuming it was 12.
The clerk let me run out and try it for fit before I paid for it.
Frank
Old 03-16-2009, 08:51 AM
I couldn't find a socket that would fit the rod.
Old 03-16-2009, 09:21 AM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
I used a 5/32 6 point worked fine..
Old 03-16-2009, 11:22 AM
Fordenthusiasts's Avatar
Fordenthusiasts Fordenthusiasts is offline
Fordenthusiasts is starting off with a positive reputation.
Not trying to highjack this thread but does anybody know what height the headlights should be aimed at from 25 feet?
Old 03-16-2009, 06:01 PM
kdy72601's Avatar
k it has afer market euros and the addjustments on the back i got them close with a 1/4" rachet and 5/32's soket but the rachet is hiting the raditor suport still need to bring them in a little bit.
Old 03-16-2009, 06:17 PM
Beamed's Avatar
Beamed Beamed is offline
Beamed is starting off with a positive reputation.
try taking off the header panel and adjusting the other mounts other than the one sticking up
Old 03-17-2009, 01:14 PM
kdy72601's Avatar
foud out snap-on carries the perfect tool RBYF445, Wrench, Ratcheting Headlight think i can get it aimed perfectly with that.
Aim headlights? thi 1968-2013 Full Size Vans 2 01-07-2016 07:32 AM
Headlight adjustment CASTMASTER Excursion - King of SUVs 0 01-21-2014 03:19 PM
Stock headlight aiming instructions. 77 F150 derherr65 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-09-2007 05:24 PM
Aiming headlights zarillus Expedition & Navigator 3 09-08-2004 12:20 PM
F250 Headlights Adjustment? Little Bro 1961 - 1966 F-100 & Larger F-Series Trucks 1 08-10-2004 01:09 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
