Removing Light Scratches?? - Ford Truck Enthusiasts Forums
Old 03-15-2009, 05:30 PM
ggwash21's Avatar
ggwash21 ggwash21 is offline
ggwash21 is starting off with a positive reputation.
Ok so I'm looking for the best wax or scratch removers. I have light scratches from light brush during hunting season and i wanna know what you guys think the best brand would be to use. I have a darker blue paint if that helps.
Edit/Delete Message
Old 03-15-2009, 05:52 PM
cableguy1224 cableguy1224 is offline
cableguy1224 is starting off with a positive reputation.
I am a huge fan of mothers wax and cleaners, they seem to work great!!
Old 03-15-2009, 07:42 PM
magnet1's Avatar
magnet1 magnet1 is offline
magnet1 is starting off with a positive reputation.
I use EAGLE ONE. They offer cleaners, and swirl removers. As for wax, they have the Nano-polish which works really well on dark vehicles, especially black like mine. It really helps fill in the swirls and light scratches. Just remember...side to side when polishing, not old school circles on dark paint. It would also be a good idea to clay it before you wax it to make sure you have all the contaminants out of the clear coat.
Old 03-15-2009, 08:18 PM
ggwash21's Avatar
Quote:
sounds like a good sunday project....
Old 03-15-2009, 08:22 PM
Big-Red-Lariat's Avatar
Big-Red-Lariat Big-Red-Lariat is offline
Big-Red-Lariat is starting off with a positive reputation.
clay it? This is a new verb to me. Can u elaborate?
Old 03-15-2009, 11:11 PM
Clay bars work VERY well to clean the paint, I don't believe they remove scratch's though. I was amazed when I first used mothers brand clay bars, the remove ALL paint contaminants. Check out the link below, they are magical!!
Mothers® California Gold® Clay Bar System
Old 03-15-2009, 11:12 PM
evilwayz7's Avatar
evilwayz7 evilwayz7 is offline
evilwayz7 is starting off with a positive reputation.
It's a clay bar. If you go to youtube and type in How to clay bar you can find videos on it.
Old 03-15-2009, 11:59 PM
jet canada jet canada is offline
jet canada is starting off with a positive reputation.
ok ...have you heard of a product called Plexus?? it is the best miracle in a can for scratches...you will not believe it!!! go to their web at www.plexus.com i am pretty sure that is it...not cheap though...17$ a can....check it out!!!
Old 03-16-2009, 12:14 AM
the link is Introducing Plexus Plastic Cleaner and that is the BEST miracle in a can for scratches...you will not believe it...i always have at least 2 cans on hand ...it's amazing on all types of paint/plastic
Old 03-16-2009, 02:17 PM
fitz888's Avatar
fitz888 fitz888 is offline
fitz888 is starting off with a positive reputation.
Where can you get a can I dont want a whole case
Old 03-16-2009, 02:41 PM
try motorcycle shops or jet ski shops ...they usually have this stuff...good luck
Old 03-16-2009, 04:39 PM
ggwash21's Avatar
Found it on Amazon
Amazon.com: plexus
Old 03-16-2009, 09:01 PM
Gparcels Gparcels is offline
Gparcels is starting off with a positive reputation.
Check out these products, 3M Finesse-it™ and 3M™ Compounds, Polishes and Accessories. Do a google search on their product line. I have had many black vehicles, cars and trucks and using the Finesse-it with a buffing wheel willl produce a mirrior like shine, then wax to protect. (Weekend project).
Old 03-17-2009, 04:45 AM
James_24_85's Avatar
James_24_85 James_24_85 is offline
James_24_85 is starting off with a positive reputation.
I am a big fan of the ice products by turtle wax, I would try the liquid clay bar then the wax, then the spray detailer inbetween waxes. works pretty well for me. Removes light scratches
Old 03-17-2009, 02:01 PM
xjcamaro89's Avatar
xjcamaro89 xjcamaro89 is offline
xjcamaro89 is gaining momentum as a positive member of FTE.
I have found for best and fast results that 3M products work the best for light scratches that wax doesnt cover. Walmart has two kinds of scratch removers (At least at the one near me) made by 3M. Both in little bottles so you dont have to got to the auto body shop and buy a big bottle. One kind is called the rubbing compound and the other is called the finish restore. I use the rubbing compound first as it is more abrasive, applying it with a clean lint free towel, then the finish restore to bring up the shine. I work it in a small area at a time in a fast circular motion, sort of like your waxing it in a small section. Keep rubbing in circles until the paste almost disappears, then use a clean towel and wipe off the rest. Then repeat with the next kind, or next area. For light scratches it works really good. For deeper scratches you can use the same stuff but you might not be able to do it by hand, you might need a buffer/polisher, because when you use rubbing compounds your actually creating heat in the finish that blends the finish together covering the scratch. Now dont get all worried and stuff, doing it by hand will not hurt you finish, its stated on the bottle, in fact the only thing you will notice about your finish when your done doing it by hand is the scratch will be gone.
Removing scratches in paint Sunline Fan Excursion - King of SUVs 24 03-21-2012 11:35 AM
Refinish 18 year old plastic tail lights phoneman91 Appearance & Dress-Up 2 04-03-2010 08:25 PM
Removing Light Scratches?? ggwash21 Appearance & Dress-Up 1 03-15-2009 10:46 PM
Remove Light scratches from interior Dash and Trim MilesTeg Appearance & Dress-Up 0 03-19-2005 04:56 PM
How to remove scratches from chrome bumper? phoneman71 Appearance & Dress-Up 1 02-01-2005 02:52 AM
Tags
display, ford, light, radio, remove, scratches
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
