"07" Crown Vic Conversion in a 1959 s/b - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 05-29-2009, 11:35 PM
2losteve 2losteve is offline
2losteve is starting off with a positive reputation.
Thanx for the photos Donald. The guy doing the work appears to have good fab skills.
  #32
Old 05-31-2009, 02:45 PM
fatfenders56's Avatar
fatfenders56 fatfenders56 is offline
fatfenders56 has a good reputation on FTE.fatfenders56 has a good reputation on FTE.fatfenders56 has a good reputation on FTE.
I used a Lincoln Continental , narrowed the clip 3 inches, A-arms 1 inch, lots of work but these things are great
  #33
Old 05-31-2009, 09:33 PM
tacson's Avatar
tacson tacson is offline
tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.
I have to agree with you Fatfenders. These front ends right great.
  #34
Old 07-23-2009, 09:30 PM
tacson's Avatar
Quote:
Originally Posted by 2losteve View Post
The reason that I was asking about the year of the frame is 'cuz I've not seen such short forward cab mounts before.
I'm not sure what the differences are on a '57-'60 frame (from the '53-'56). I believe it is in the length.
I put a Camaro on my '56 but I have a '57 that I've not yet started on. I want to use a Mod motor in it and the CV frnt clip certainly looks like an option. My pick-a-part is full of those cars.
Steve got an update for you. I talked to my friend who taught me what little I know about FOMOCO front ends and who's work the photos are with exception to mine. The reason the cab mounts are shorter is because the cab was originally used as a F600 Fire Truck.
  #35
Old 07-24-2009, 12:46 AM
Thanx for the update Donald !
  #36
Old 07-24-2009, 12:40 PM
Jonas1022's Avatar
Jonas1022 Jonas1022 is offline
Jonas1022 is starting off with a positive reputation.
Why not toss the truck frame, and utilize the cars' frame to achieve what you want? I guess that I'm lost in what you are trying to achieve vs. what you can utilize for an improvement.
  #37
Old 07-27-2009, 11:19 PM
Quote:
If you think you are lost now, wait until you try to do a frame swap with this, my gallery is full of photos af a Lincoln Continental swap, good luck
  #38
Old 07-27-2009, 11:22 PM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
Darksiders. Can't leave well enough alone.
  #39
Old 11-08-2009, 10:17 PM
crewter crewter is offline
crewter is starting off with a positive reputation.
Hello. I am new here. I subscribed because I was interested in the Crown Vic swap for a 58 f100. I was hoping to do the swap and run the cop car steel wheels or some mustang wheels. My truck will be a rat/shop truck. I cant find many photos of 57 to 60 longbeds that are hot/rat rodded. Anybody got any?
Brad
  #40
Old 11-27-2009, 11:20 AM
72-F100-4V 72-F100-4V is offline
72-F100-4V is starting off with a positive reputation.
http://www.ford-trucks.com/forums/75...72-f100-2.html
Here is a link to my page showing the trailing arm brackets in action. I think if this suspension works on the older trucks it would open up alot of options for the DIY builders. No more dakota,volare, MII, fatman suspensions to weld in.
  #41
Old 09-20-2010, 11:32 AM
SixtySix Ford's Avatar
SixtySix Ford SixtySix Ford is offline
SixtySix Ford is starting off with a positive reputation.
any updates on your build?
  #42
Old 11-29-2010, 03:20 PM
Fauj's Avatar
Fauj Fauj is offline
Fauj is starting off with a positive reputation.
I have been lurking here a while and learned hopefully more that I will ever need to use. Lots of bright people on here!
I have been looking to use the newer CV front end on a 57-60 F100. As has been mentioned, the problem looks to be with the spindle. So my question would be to the Ford Parts guys here, is there a spindle that would fit between the control arms/ball joints that has less off set than the CV piece? And if there is one, couldn't we just use what ever brake assembly fits the new spindle with less off set. I don't have a CV around to be measuring.
Just my two Cents worth of speculation.
Thanks,
  #43
Old 11-29-2010, 08:36 PM
Old F1's Avatar
Old F1 Old F1 is offline
Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.
Quote:
I donít think there is ÖÖÖand if there was I think the darkside animals here would be all over it and you would know about it.
I donít think it is the spindle as such, itís the A arm length, but that is a big can of worms. Look again at this post especially the picture of the A arm and spindle.
have you read this post;
http://www.ford-trucks.com/forums/96...ap-update.html
  #44
Old 11-29-2010, 09:08 PM
Fauj's Avatar
F1 thanks for the reply. It seems that the A arm length is fixed due to having the spring located in it. But the spindle looked like it was designed to move the rotor further out probably for handling (wider is better). I know that it is a front steer, so the potential replacement spindles would have to have to be front steer as well. Looking closely at the pic, it just seems to me that the rotor is considerably further away from the ball joint than the older models I am used to. Even my 99 F150 doesn't have them that far out. If this doesn't work, it may be a frame transplant from a newer model Ford truck.
I wish I had more wrecking yards near by, it would make for a great field trip.
edit: I did check out Romak's build, it is one of several that got me thinking about this. He used the late model Bullitt wheels that have the negative off set. They look good, but I want to use steel wheels and still keep the rubber out of the fender.
Thanks again for the response.
  #45
Old 11-29-2010, 11:33 PM
hotfalcoon's Avatar
hotfalcoon hotfalcoon is offline
hotfalcoon is starting off with a positive reputation.
I think this is what you are looking for.
1959 f100 frame swap 86ford94 1957 - 1960 F100 & Larger F-Series Trucks 6 02-18-2016 04:48 PM
1959 transmission mngriz 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 10-17-2014 01:54 PM
Floor pans 1959 F100 jamhh 1957 - 1960 F100 & Larger F-Series Trucks 6 03-12-2013 11:08 AM
1959 f100 rodriguezfords 1957 - 1960 F100 & Larger F-Series Trucks 9 07-19-2012 02:41 PM
1976 inline 300 swap in 1959 f100 rodriguezfords Ford Inline Six, 200, 250, 4.9L / 300 1 03-22-2008 08:31 AM
Tags
1956, 1959, clip, conversions, crown, f100, ford, frame, front, ifs, suspension, swap, track, vic, victoria, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
