2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
More Leaks!
Old 03-16-2009, 10:38 AM
berry1234's Avatar
berry1234
berry1234 is offline
More Leaks!
After reading a post about front axles leaking I crawled under my 08 4x2 and sure enough, with 22,000miles, the rear axle is leaking. It's leaking on the driver side of the differential and both sides of where the axle meats the wheels-sorry not a mechanic-not sure what part that is. Take a look.
Old 03-16-2009, 12:20 PM
clearnetedm's Avatar
clearnetedm
clearnetedm is offline
Thats the exact place mine is leaking. It's in the shop right now for the work and should have it back this afternoon and I'll report the details. They are also looking at a vibration at 100KM+ in the rear end that might be related, but I suspect that will come back "no fault found".
Although mine seemed to be leaking a little more with a small puddle in the driveway, not sure if seepage is normal at all.
Old 03-16-2009, 06:34 PM
clearnetedm
Truck is back and they replaced a rear axle stub shaft seal. Guy says its pretty common on these rigs. They weren't able to find the vibration which is fine for now, might just be in my head now that I'm thinking of leaking axle's. They said bring it back if it gets any worse.
Old 03-16-2009, 08:24 PM
clearnetedm
This is what mine looked like before the fix:
2008 Expedition Max 4x4 Limited
Old 03-17-2009, 10:28 AM
berry1234's Avatar
berry1234
Now that is bad! Were your outer seal near the rotors leaking too?
Old 03-17-2009, 10:36 AM
clearnetedm
No just that one for now. I'm glad I read on another thread on this or I would have never gone under to have a look. I'm going to make sure I get under there at least once a month just to keep an eye on things.
BTW this was the rear diff and the axle towards the driverside tire.
berry1234
03-22-2010 03:32 PM
berry1234
17
06-26-2009 04:21 PM
berry1234
06-20-2009 08:18 AM
berry1234
38
03-31-2009 08:26 PM
Ogio
12-06-2007 09:45 PM
Quick Reply: More Leaks!
